Memory-Motherboard speed compatibility
Solved by minibois,
This board has about 36 sets on their (Ryzen 3rd gen) QVL that can run at 3600Mhz, generally sets with Samsung chips on it.
So it's safe to say it will support 3600Mhz, whether your specific set will work, depends on what you get.
This was the cheapest set I found on PCPartPicker that is also on their memory QVL, but you could look a bit further for more options..
Memory QVL:
EDIT: if you aren't familiar with reading an Asus QVL, this is the column you should look at:
That of course lines up with the Part no. on the left.
