Need help with fps drop
Solved by MadAnt250,
On 11/24/2019 at 1:21 PM, TobiSan said:On 11/24/2019 at 1:14 PM, MadAnt250 said:The xeon e3 1240 has a
TDP 80°Cif you are getting close to that I suggest doing something about your cooling.Actually yes I checked it but the temp goes to 70 in most games.
Disregard that statement, I meant operating temp and I pasted the TDP wattage, oops. Your max operating temp I believe is around 69 degrees C, so you are running hot. I suggest cleaning the cooler, putting new thermal paste and making sure you have good air flow in your case.
Edit: I think the temp I stated is at the heat spreader and not the junction temp, I could not find info on your junction temp but, 67 degrees in chrome is way hot considering that I am at 30 degrees right now with a stock intel cooler.
