I have a gtx 1070ti and and in a few days i'll have an i5-9600k with a cpu cooler, 16 gb ram, and 1 ssd all on a mATX motherboard and I also have a 650W 80+ silver PSU.
My case is 400x400x185mm (HxDxW) and has only 1 fan in the front.,
Will my computer overheat or something? Should I be worried?
Do I need to get a bigger case with more fans or will it be fine? (I don't really have money atm)
https://linustechtips.com/topic/1125252-case-fan/
What case is it? Size doesnt matter at all when it comes to cooling potential. It's all about how you can use it. If your case is built to provide good cooling, then the front fan should be able to pull in good air (though I would still recommend adding at least one fan as an exhaust in the future)
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058444
It's an old Segotep Baymini
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058451
is already yours or are you buying it? that case looks like it only has air intake at the small opening in the front.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058474
Just now, Rafaelos said:
I have it
is there any place in the front except for that small opening at the bottom front of the case that can suck air in? because unless you use fans that is actually like strong enough to suck enough air through that for the entire case, i dont think enough fresh air can go in. Unless you plan to mod that case and put holes at the front(which is a bit janky but works) then i think thats a hotbox.
CURRENT PC SPECS
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058488
You should buy a Case. Only 1 Fan in the Front is shit.
The Temps of your Hardware will go up to an unhealthy degree.
There are decent ones around 50 Bucks, if you dont want spend much.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058498
Yep, those holes are the only openings on the front
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058502
ye, unless you plan to mod that case, its better to just buy a new one
CURRENT PC SPECS
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058556
2 minutes ago, Rafaelos said:
Any recommendations under $50? It would be preferable to have atleast 2 fans in the front
id suggest any case with mesh front, not glass or plastic. but mesh. im not a case expert so yea. wait for the reply of the others and what is your required space(is the GPU too big? is the CPU cooler short enough ect) so you need to take in to consideration the case clearances. check for the component dimensions before you chose.
CURRENT PC SPECS
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058579
You could just install the parts and see how the temps are before deciding on whether or not to change anything out.
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058596
That is what i will do. My current cpu is around 55C in full load, but the 1070 ti is getting even to 83C at max settings and that worries me. If the i5 9600k will be around 60C and the gpu the same it will be ok
https://linustechtips.com/topic/1125252-case-fan/#findComment-13058942
Those aren't very low temps but still perfectly safe and seems normal.
Which 1070 Ti do you have? 60c is probably unrealistically low for the gpu.
https://linustechtips.com/topic/1125252-case-fan/#findComment-13063681
sorry I didn't express myself properly. My gpu gets to around 77-83 in full load, and if it remains the same temperature as now with my new additions i'll be satisfied
https://linustechtips.com/topic/1125252-case-fan/#findComment-13064575
On 11/21/2019 at 9:25 PM, Rafaelos said:
sorry I didn't express myself properly. My GPU gets to around 77-83 in full load, and if it remains the same temperature as now with my new additions i'll be satisfied
i think when you reach 83, it usually stays like that and starts to throttle down just to keep the temps low.
CURRENT PC SPECS
https://linustechtips.com/topic/1125252-case-fan/#findComment-13066382
