CPU cooler making weird noises
Solved by VIVO-US,
Are you talking about that buzzing sound? I've often heard that from cheap PWM fans, which may have low frequency PWM controllers. The pulsing from these can cause a buzzing noise to resonate through the plastic parts. Better quality PWM fans often have higher frequency controllers to run more quietly.
$30 is kind of a terrible deal on that cooler, which is barely better than the stock Intel...
