Wouldn't even bother with an AIO in that case due to the lack of airflow
https://linustechtips.com/topic/1124239-case-cooling-options/#findComment-13050653
ooooooh another hotbox case!  this could work but you need like 2 120mm fans in front with like the suction of a vacuum to actually pull air in >.<
say hello to the noctua industrial fans
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1124239-case-cooling-options/#findComment-13050656
Yeah,that case will make the system nice and toasty.
OP should go for a Cooler Master MB511
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1124239-case-cooling-options/#findComment-13050667
Cheap case that doesnt have trash airflow like that will be the Deepcool matrexx 30, Thermaltake H18, Cooler Master N200, Fractal Design focus G mini and the Corsair 88R
Desktop benching:
https://linustechtips.com/topic/1124239-case-cooling-options/#findComment-13050783
thx for the list of cases!
If you know any, could u also list atx cases and tell me if a micro atx board will look good in an atx case?
I am probably going to upgrade my motherboard over the years
https://linustechtips.com/topic/1124239-case-cooling-options/#findComment-13051558
1 minute ago, GeneralGusher said:
Yeah i was also thinking of getting another case later on
Put that as a priority, an AIO will choke in that case.
https://linustechtips.com/topic/1124239-case-cooling-options/#findComment-13051560
Cooler Master NR600, H500, Fractal Design Meshify C/S2, Corsair 275R Airflow edition, Phanteks P400A, on a budget the Cougar MX330 and Fractal Design Focus G
Desktop benching:
https://linustechtips.com/topic/1124239-case-cooling-options/#findComment-13051585
