7 minutes ago, Pixel2k2k said:
ryzen 5 2600
Make sure you quote us or use @OlympicAssEater so we see your responses
Have you checked for any invasive background tasks?
Primary PC:
PSU tier list
How many watts do I need?
Either there is some very heavy task running in the background or your cooling is broken/installed incorrectly I would think.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
Check taht you have under 1.4V on your cpu. Disable precision overdrive if you can. Mount new thermal paste (do not put too much) and cooler back. Buy another cooler. If does not help, your cpu might be broken.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
Just now, Pixel2k2k said:
@Fasauceome @martward there are no tasks except for opera taking 15% cpu but i think its not that much right?
No that shouldn't be it. I would check the cpu cooler, might not be mounted correctly.
My System:
@martward should i turn off the pc? What should i do to check if cooler is mounted correctly?
That's a good first step
Primary PC:
PSU tier list
Probably yeah. Did you build it yourself?
In that case:
- Did you remember to remove the plastic on the cooler?
- Did you remember to apply thermal paste?
- Is the cooler straight on the cpu and relatively tight on there?
My System:
@martward No. It was build by local pc store, was looking very good and stable, and at the time i needed a new pc, so i bought it.
Then I wouldn't touch it and ask the people at the pc store to fix it for you. If you start reviewing with it your warranty may be void so just let then figure it out.
My System:
