Hey All.
I wanted to ask how you guys clean your PC from Dust?!
It is a stupid question to ask, but what I mean by asking that, if you using Gas Duster - the can with compressed air, or do you use the compressor.
If you do use a compressor, for how much PSI do you place the machine?
I am asking as I do not wanna buy from time to time the gas can, and prefer to get my own compressor.
The issue that I am not having apartments to place it, so I though to get a small, portable compressor, like the one we use for tires.
https://www.amazon.com/TIREWELL-12V-Tire-Inflator-Compressor/dp/B06ZXR9P6R/ref=sr_1_9?crid=3BNLI3V14Z13F&keywords=portable+compressor&qid=1573650785&sprefix=portable+com%2Caps%2C288&sr=8-9
The issue as I see, is that it is not provide constant air flow with the same PSI strenght, so I find that this tool can be usless.
And here where I wanted to ask you, if anyone of you tried to use portable compressor. Did it work as you were planing.
Did it did the job well done?!
Also, maybe instead of PSI, maybe I need to focus on the CFM?
Maybe any one also have a reference for a video with example, as I couldn't find.
Thanks
CPU - AMD 5800XMotherboard - ROG STRIX B550-E GAMING , Memory  - G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 ,
GPU - NVIDIA GeForce RTX 3080 Ti MSI SUPRIM X 12G,  Case - 4000D AIRFLOW Tempered Glass Mid - Tower ATX Case - Black ,
Storage - Samsung 970 EvoPlus 500GB - Samsung 870 EVO 1TB + 6TB HDD,
PSU - Corsair HX1000 , Display -  ASUS TUF Gaming VG27A 165HZ + Dell 24 UltraSharp Monitor , Cooling - Noctua NH-D15 Black ,
Keyboard - Razer Stalker , Mouse - Logitec G502 Wireless , Operating System - Win 10 Pro ,
Sound - Logitech Z906 5.1 THX Surround Sound Speaker System
https://linustechtips.com/topic/1123257-pc-case-cleaning/
i used a vaccum cleaner on the outside parts and then used compressed air on the parts inside.
just be careful you don't hold the air can wrong and spray out the liquid
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1123257-pc-case-cleaning/#findComment-13043072
Thanks, I already cleaned PC many times.
I am looking for alternative for gas cans.
https://linustechtips.com/topic/1123257-pc-case-cleaning/#findComment-13043079
DataVac ED500 - there's also some other brands, but can't seem to recall the names of those. I can recommend the DataVac as it's very high quality and just works. I have used mine for the past 5-6 years.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1123257-pc-case-cleaning/#findComment-13043083
