Hey friends,
I bought all these parts and had Micro Center build the PC for me in January. No issues up until a week ago when I got back from a two week vacation.
I started playing Call Of Duty MW and the game crashed gave me a blue screen that says Watch Dog Violation .. I thought maybe its the game causing this but it doesn't happen to my other two friends who play the game.
I did some google research and someone recommended I pull up command promt and do a disk scan clean so ai did that.. and I got a message that said Corrupted files were found but was unable to fix .. I will post picture. Before I did this scan I had got Watch Dog Violation about 4 times.. MW would freeze end of a match after 2-3 games .. and then my computer would restart in to the blue screen and then work like normal again. After I did these two command promo scans I went into COD MW and then it happened again except I got a new blue screen issue Memory Management ..
I looked up this issue and did a Memory Scan and that came back with no issues..After I did the memory scan I played 2-3 games of MW and did not see the issue come back but I want to try again after work today.
idk what to do .. just need someone to walk me through this. My computer parts are all from January.
Case - NZXT H500i
Mobo - ASUS ROG Strix X470-F Gaming
CPU - Ryzen 2700x
CPU Liquid Cooler - NZXT Kraken X52
GPU - Msi Ventus Rtx 2080
SSD - Samsung 970 EVO 500GB
HD - BarraCuda 2TB 7200RPM SATA
RAM - G.Skill Tridentz 3200MHz RGB
Power Supply -EVGA G3 850 Watt
https://linustechtips.com/topic/1122898-stressed-i-need-help/
@Teddy07 seems to have it I think.
Could theoretically be hardware, but I doubt it.  Sometimes files just corrupt.  Cosmic rays, etc..
finding which file corrupted is helpful.
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040265
Yes shouldn´t be a bid deal. Windows automatically disables corrupted sectors to prevent further use.
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040283
Yup, reinstall game first - if it continues I would do a Win 10 reinstall myself
After I checked into my ram speed - that generation of Zen is only guaranteed to work at 2933mhz with that CPU memory controller.  Anything past that is potentially unstable with XMP without fine tune overclocking (from my experience with Zen)  Make sure in BIOS you are running 2933mhz, if the issue persists, I would look into the software side next.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040301
I had a similar issue before and this fixed it, computer didnt like my 3200mhz ram, dropped it to 2933 and it fixed my issue
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040360
3 hours ago, Thenelwave said:
Hey friends,
Case - NZXT H500i
CPU - Ryzen 2700x
Ok first thing. "Watchdog" is a feature that basically communicates with the OS to say "hey" every few moments, and if it doesn't receive a response it determines that the system has locked up and initiates a reboot. You can turn it off by turning off the BIOS feature and uninstalling the watchdog driver, if that is actually how it's implemented. I've only seen it on workstation/server systems, not desktops or laptops.
With that said, the watchdog shouldn't be doing this if the hardware is working. The Watchdog driver is really not intended for a gaming PC since it might get false flags from thermal sensors not aligning with the clock speeds expected. It's intended for a system that must be in a high-availability state (eg medical or aerospace applications.)
In a sense, there is a hardware failure going on here, but you might not be able to isolate the failure without doing some swaps. Since memory was the second BSOD, it would reason to believe that the RAM is the culprit, but it could also be the memory controller on the CPU, and it's only doing it when it hits a certain thermal point.
The thing I would do is update all the drivers, even trivial nonsense like motherboard chipset and usb drivers. Then see what hardware has to be unplugged for it to stop happening. Like this might involve removing all the RAM and testing each channel/slot individually and seeing which channel/slot immediately BSOD's.
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040604
I can get fairly stable at 3600mhz with Zen (2666mhz memory controller support) but it is not 100% stable (2 dimms).  I crash maybe once a night during gaming sessions, and if I competitive game I drop the bios to 2666mhz for 100% stability.
Also only frequency I can keep when running 4 dimms (2666mhz even though the kits I have can do better etc)
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040664
5 hours ago, Teddy07 said:
Have you looked into the logfiles which files are corrupted?
Tried a reinstall of MW?
Sounds worse than it actually is.
I think it may be something very simple but im not great when it comes to this. How do I look at my logfiles?
I have not tried to reinstall MW. Will try after work!
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040949
5 hours ago, Arika S said:
first question is going to be: have you done any searching of this error on google?
and if so, what fixes have you attempted? better to know what you've attempted already instead of giving you actions that you may have already completed. because the first 3 links had potential fixes beyond to a disk scan
when I got the watch dog violation I googled it and tried the command promp scan as well as updating the driver for SATA something in my task panel. Thats it.
after the scan I got the memory management blue screen not the watch dog violation
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040953
Now if I wasn't having this issue before can it still be that ? I didnt have this problem when playing Gears of war, FFXIV, APEX ect ..
also how can I wipe my HD as well as wipe my SSD so I can do a clean install of windows ? I don' mind doing this at all
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040963
Hmm this might be a difficult one for me might have to bring it in to MC .. sucks with this being a new build and all.
might try reinstalling windows.
or I could just buy new RAM ? And see if the issue stops afterwards ?
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13040976
22 minutes ago, Teddy07 said:
The location is shown in your first picture
Do you think that may be
whats causing it ? Or it could be something totally separate ?
also the other day I was trying to uninstall Destiny 2 and cancelled it right after so the game seemed to have uninstalled but it didn't delete from my software uninstall. Not sure if that may have caused any issues.
just putting everything out there. Will check my log when I get off work
edit: will the log tell me exactly whats going on ?
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13041080
Set your ram first see if that even clears the issue, get the computer within SPEC and then see if the instability continues.  If it fixes it, its the memory controller.
The why I cant explain - but if I told you Im dealing with this similar issue myself on Zen platform suffice to say that I think that over time the memory controller degrades somehow and wont post past.
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13041165
How can I do this ? Sorry for the silly question. Also Iv only owner the PC since January
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13041238
Go into BIOS (turn off PC) by pressing ON button and spamming the ESC and F2 key on your keyboard (common BIOS booting options, if not then F11, F12 google what your board needs if this doesn't work)
Then set the RAM in the OC portion of the BIOS to 2933mhz and restart.  It may turn on and shut off on its own up to 3 times - its training the RAM timings at this frequency.  If it finds stable, it will boot.  If it does not find stable it will prompt you to go back into BIOS and try again.  If so set XMP then set 2933mhz manually, though it should be able to get its own timings.
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13041529
4 hours ago, Thenelwave said:
Two sticks 1 on the 1st slot and another on the 3rd slot
If it is a ram hardware issue
Set all ram speeds back to stock.
Use 1 ram stick at a time and run your game.
Do that for both sticks and see if you still have the same problem.
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13041629
Hey, i updated my sata thing too and my pc wouldnt boot up. You need to reinstall windows. Sorry to hear that you had same kind of problem that i had.
Download windows meadia creation tool (if u can boot to safe mode with wifi on). Convert your windewos to bootable usb drive (remember what your product key is), and go into bios and boot from usb and delete everything in your ssd and hdd and put your windows from your usb to your ssd or hdd.
https://www.howtogeek.com/224342/how-to-clean-install-windows-10/
Make sure to choose delete everyhting and make sure you put your windows to the usb not your harddrives
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1122898-stressed-i-need-help/#findComment-13042781
