4-Pin ATX power needed?
Solved by Stormseeker9,
4 minutes ago, BulletSingularity said:PCPartPicker is saying that my motherboard has a 4-pin ATX power connector and that my power supply doesn't have it, will this affect my performance a lot because i wont be doing extreme overclocking on my i7-9700k and moderate overclocking on my RTX 2070 Super
What power supply are you planning on using?
and if PCP means the extra 4 pin connection, then no.
