it means your overclock is not stable
Desktop benching:
4.1GHZ is something you don't usually get under 1.40 volts. I overclock Ryzen CPU by setting Vcore to 1.45volts, then increasing frequecy until iT where is crash on Cinebench R15 after 10 runs or Aida64 stress test. Then is lower CPU frequency about 100mhz, and now i lower Vcore until it crash again.
So lets say you increase Vcore to 1.45 and the CPU doesnt crash at 4.05ghz but crashed at 4.1ghz, i will lower the frequency to 4.0GHZ. Thats you probable max stable frequency, i now lower Vcore until it crash again, so lets say you CPU crashed after 2 pass of Cinebench at 1.38 volts, increase voltage to 1.40 and stress test for a good 15 minutes at least. If it doesnt crash what i like to do is increase it again to like 1.42 vcore and call it a day. You can stress as much as you want, but thats what i do and never had a crash so far and i takes about an hour or two to overclock, and its better then stock.
Using Voltage offset is a good thing instead of using static voltage, it helps to cool the CPU at idle.
Also try to reduce overclock of the CPU before OCing the Memory, and i would OC memory before the CPU
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
You really don't want to go over 1.38v on Zen+ though AFAIK. A 100Mhz increase probably isn't worth it if you can't push that at 1.4v or less.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Depends on each CPUs, i know my 2700 will run 1.60volts with 4.3GHZ, but that was for Extreme Overclocking purpose. As AMD_Robert said, 1.45 is within safe voltage and 1.2 VSOC is maximum safe, that being said, the CPU gets really hot with 1.45, hotter then i can live with for gaming.
I'm personally running 4.125GHZ on my 2700 with 1.38Vcore and 1.1Vsoc and don't worry about the CPU dying anytime soon. Memory is a 1.45volts and is still within safe voltage too, some people have been running their 1.35v rated memory at 1.5volts without any issues for years.
Really? I've seen a lot of members here , myself included, having 4.1Ghz OCs under 1.4V.  Mine for example runs at 1.32V. Either we are the top percentage of lucky silicon lottery members or they overclock better then you expect :D
I believe I got my CPU to 4.1GHz @1.38v, but I'll have to double check and see.
Current PC (Second Build) : CPU: Ryzen 5 1600 (OC @3.8GHz, sometimes pushed to 4GHz) RAM: 16gb Corsair Vengeance RGB Pro DDR4-2666 (OC @2733Mhz, sometimes pushed to 2800 for testing purposes)   GPU: PowerColor Radeon RX570 8gb MOBO: ASRock B450m Pro4 SSD: Inland 120gb HDD: 1tb Seagate Barracuda PSU: Cooler Master Masterwatt 500w Lite Case: NZXT H500 OS: Arch Linux+ KDE Plasma [Desktop Environment] & Windows 10 Pro [Broken due to grub 50% of the time]
Accessories: Mouse: Alienware AW958 Elite Keyboard: Corsair K63 Wireless  Headphones: Samsung Level On Pro
Phone (waiting on arrival): Samsung Galaxy Note 9
You my friend won the silicon lottery AFAIK, i'm running my 2700 4.125ghz at 1.38, i'm probably able to run it 95% safe at 1.35 but i just want it dead stable. 1.32 at 4.1ghz i just can't, 4ghz i'm probably able to do it.
There is a point with Zen+ where you need to increase voltage a fair amount to get lets say 500 more mhz.
Oh i am sorry, maybe there was a misunderstanding. For me , I am talking about my Ryzen 5 2600 since that's what the original post is about. Don't know anything about how the 2700 behave!
