Hello everyone, I am new to the community. But been watching all the YouTube funny and crazy creations. I need help to build gaming PC, if possible be able to do some multitasking on it, like have a browser open with few pages while game runs in background. I live 30 minutes from micro center store, they will build it for me, I am not able to do that myself. Which probably will add to the cost of the computer.
I am in USA, budget $2000-2500. I was thinking mid size case, that later will let me to upgrade future components, technology moves with such fast pace, things get out date the moment you get them.  I don't need any rgb or water cooling (I believe that air cooling should be ok, may be I am wrong about that) but that's why I need your advise. I have monitor, keyboard, and mouse that are great for gaming. I was hopping to do that on Black Friday sales that is coming up.
Thank you.
https://linustechtips.com/topic/1121436-need-help-with-gaming-pc-build/
Hello,
So the overkill machine :
The good stuff :
And the budget :
I would go with something like this since you're primary goal is gaming without workstation style work. I know some people are going to say don't go intel because you get almost the same performance with ryzen at a cheaper price. But, micro center sells the 9700k for $300 and it performs better in gaming. If you want to get into video rendering, or something that is heavily multi threaded then I would consider the 3700x or 3900x.
Bad motherboard, go for the Aorus Elite.
Overpriced Samsung SSD, you can remove it. Downgrade the 660p for 1Tb.
Not the best GPU at that price the FE is better. Get Aorus, Strix, Trio, AMP or FTW3.
And that G3 is a crappy PSU/fire hazard.
I mean I disagree with almost everything you've said.
  • Mobo could be better but its fine for the 9700k.
  • Samsung SSD are not "overpriced" they are higher quality, more reliable, and much faster.
  • You don't know OP's storage needs so you can't make a blatant statement like "downgrade the 660p for 1tb"
  • The FE card is not better, the gigabyte triple fan is one of the cheapest, quietest, and best performing 2080 supers.
  • And you're right about the G3, I thought I clicked on the G2. He should definitely change that.
It can't OC an i5 so i7, unless it's a 9700 non k, there is no point in using it.
Overpriced when most brand have a 5 years warranty too for a margin gain of write/read speed.
If OP needs more storage there are a lot of HDD for storage (4TB 7200RPM for 100$).
At that price point the FE is better (700$ vs 720$) since they equal each other.
^^^ IDK much on this specific mobo, but I do know Gigabyte boards are much better on Z390 though, and at every price point up to $500 or so they consistently offer the best VRMs.
Samsung SSDs are a bit overpriced, but a Sabrent Rocket or SX8200 Pro would be a vastly better choice than the 660p, IIRC at around 60% capacity it starts getting reeeeeeeeeally slow.
If you can afford to got all SSD, dewit. If not, HDDs are still damn good options for mass storage, and way cheaper per GB.
Also, don't the Turing FE models have better binned chips? IIRC Nvidia kept the best bins for their FE cards.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Oh I didn't see the SX8200 and for the Sabrent there are rumors of specs change atm so I'm trying to avoid it. I have one and it works as intended though. Also I used an HP EX920 instead because I see it recommended quite often.
True about going full SSD if you can.
I think they do indeed!
Its like a fine motherboard, its not the best if you want to really push the chip. A lot of people recommend like $300 motherboards that are meant for extreme over clockers when most people don't enable overclocking or just enable all core sync.
I havne't experienced the 60% slow down with my 660p. I've used about 70% of it and my games still load fast. Samsung SSDs are more expensive because they don't use flash storage that is as cheap as the competition, spend more on the memory controller, and implement things like heat spreaders to keep the drive running fast under load. My 960 has been running strong for around 3 years now, I have no complaints.
Thats always been the rumor, but no one has ever proved it. A dual slot cooler with only two fans isn't really enough to cool the 2080 class card quietly. My 2070 super (same GPU core as the 2080) gets loud under heavy load even after undervaluing and repasting. 20$ for a card that runs at a higher clock speed and quieter is personally a no brainer.
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($324.99 @ Amazon)
CPU Cooler: ARCTIC LIQUID FREEZER II 360 56.3 CFM Liquid CPU Cooler  ($75.73 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS ATX AM4 Motherboard  ($164.99 @ B&H)
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3000 Memory  ($102.99 @ Newegg)
Storage: Inland Premium 1 TB M.2-2280 NVME Solid State Drive  ($104.99 @ Amazon)
Video Card: MSI GeForce RTX 2080 Ti 11 GB VENTUS OC Video Card  ($1059.99 @ Amazon)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  ($79.99 @ Best Buy)
Power Supply: BitFenix Whisper M 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.98 @ Amazon)
Total: $1993.65
Generated by PCPartPicker 2019-11-07 20:39 EST-0500
Do you need a monitor, keyboard, mouse, speakers/headset included?
What games do you want to play?
Why do you say you cant build yourself? I am not exaggerating when I say it's like legos with screws. All you need is a Phillip's screwdriver.
I have monitor, keyboard, mouse, speakers/headset. The new game like red dead redemption 2 just came out, my PC cant handle it.
I am very bad with building that kind stuff and don't want to screw up that amount of money.
Also if anything goes wrong I can bring to the store and its on them to fix it.
My current PC Its alienware x51 desktop small case.
