10 minutes ago, Dallas Beckwith said:
How good is this case i honestly do not know I am in the market for a large sized case with comparability with multiple rads.
https://www.microcenter.com/product/482932/View_71_RGB_ATX_Full-Tower_Computer_Case_-_Black
Hey, welcome!
First impressions are the front intake vents look pretty small, so airflow might not be the best. If the front drive cages are removable that will help. Otherwise looks okay, if not a bit expensive. Are you drawn to the full tempered glass look?
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1121036-case-review/#findComment-13025635
Wait for Black Friday, there's bound to be amazing sales on cases.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1121036-case-review/#findComment-13025646
3 minutes ago, Dallas Beckwith said:
Yes I am drawn more towards a full tempered glass look.
Make sure to quote or tag people so they see your reply.
Since you linked Microcenter I'm guessing you live near one. Might be worth going and checking some out in person to get a better idea of build quality, features, etc.
Agree with above, might be worth waiting to see what deals you can find closer to the holidays if you're not in a hurry to buy right now.
https://linustechtips.com/topic/1121036-case-review/#findComment-13025660
I agree with the black Friday. and i live near one but its still about 3 hours away.
https://linustechtips.com/topic/1121036-case-review/#findComment-13025662
Haha, you and I have very different views on "near" if that's the case!
https://linustechtips.com/topic/1121036-case-review/#findComment-13025670
1 minute ago, Dallas Beckwith said:
Probably haha. but  ill try and keep looking i have watched many reviews on it. they have all said that the removable drive cage helps alot.
Options for full tempered glass are much more limited compared to just side panels.
If the reviews seem favorable it's likely a decent option.
I think Rosewill and NZXT make 4 sided glass cases too. Might be worth a serach.
https://linustechtips.com/topic/1121036-case-review/#findComment-13025702
https://www.newegg.com/black-rosewill-cullinan-v500-atx-mid-tower/p/N82E16811147292
This is one i found
https://linustechtips.com/topic/1121036-case-review/#findComment-13026081
Case is overall good, though it's a bit "big"
Gamers nexus compared it head to head with the Corsair 570 which at the time was it's direct competitor (lots of glass)
https://www.gamersnexus.net/hwreviews/3071-thermaltake-view-71-case-review-vs-570x
Quote
The View 71 TG is a case that some people will buy just for the glass. For those people, it doesn’t need to be well-constructed or have good airflow, it just needs to look good and cost less than the Corsair 570X. And it does, sort of. As of this writing, the 570X is $170 on Newegg counting a sale and a $10 rebate, while the non-RGB View 71 TG is $170 from the start. Thermaltake has priced its case competitively.
As for performance, the View 71 does a lot better than might be expected: with one additional fan, it outperforms the 570X (but now costs more). The two stock Riing fans do their job well and are worth keeping, but an additional fan is worth the cost. Paying an extra $30 for the RGB version of the case that includes three RGB Riing fans isn’t really worth it; but buying a single extra blue Riing fan instead would cost $18 on Newegg.
If I might throw in a case for "radiator compatibility", the Lian Li PC-O11D is an excellent all around case , and while it doesnt have 420mm rad support, it can comfortably fit tripple 360mm rads in a smaller package.
https://linustechtips.com/topic/1121036-case-review/#findComment-13028358
