Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1120668-white-matx-case/#findComment-13022410
White cases are a bit harder to find but:
Apevia - QPACK 3
Bitfenix - Phenom M, Prodigy M
Corsair - Air 240 (I personally know this one is Discontinued, use ebay). Air 280X, Air 540
In Win - 301
NZXT - 400 Series, 500 Series
Phanteks - Enthoo Evolv
Silver:
Thermaltake Level 20 VT
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
42U Server Rack: ISP Modem + UDM-SE + APC 3kVA UPS + 3x Dell Precision 5820 + TBD
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
https://linustechtips.com/topic/1120668-white-matx-case/#findComment-13022430
24 minutes ago, DoctorNick said:
Whoa I never seen this case before. Will take this case into consideration, thanks! My budget is less than $100 and my location is Hawaii.
https://linustechtips.com/topic/1120668-white-matx-case/#findComment-13022446
https://pcpartpicker.com/product/wd6qqs/silverstone-rl08bw-rgb-microatx-mini-tower-case-sst-rl08bw-rgb
https://www.amazon.com/dp/B06XXSWWX6/ref=twister_B07MW36JJW?_encoding=UTF8&psc=1
Some more suggestions, though the PS15 is still my overall favorite mATX case currently (though the RL08 is good for longer GPU's)
https://linustechtips.com/topic/1120668-white-matx-case/#findComment-13023763
Jonsbo C3 or In Win 301 for its exceptional build quality and the most compact mainstream mATX case available. If you want to go the more enthusiast level, the Cerberus Sliger then.
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
https://linustechtips.com/topic/1120668-white-matx-case/#findComment-13023919
