Aftermarket VRM cooling - Aorus B450M Ryzen 2700
Solved by Gorgon,
On 11/4/2019 at 3:29 AM, Jenshiye said:In my case it would be lm-sensors and that isn't picking up this board (so I am flying blind).
Sorry for necro'ing this thread but I just had the VRM on my Aorus b450m DS3H fail catastrophically. I was running a Compute workload on all cores on a stock 2700x and it did take several months for the VRM to melt down even with no over-clock and a Hyper 212
FYI - to get lm-sensors working under Linux for any Gigabyte (and a lot of others) you will need an updated it87 package for lm-sensors to get the kernel driver working. You can find one that works here so you can monitor the sensors. PM me if you have trouble getting the /etc/sensors.d/ .conf file working
Share
Followers
1
