     I posted an article today after searching through the forums to check it somebody had posted it already and from what I had found, nobody had. Then after I had posted it, someone wrote on my video that it was already posted by someone else and linked me to the post.
I really think that there should be a better system in place where you can search for previously posted topics because some people decide not to put tags in their post meaning that it's really hard to find.
Thanks,
Blueprint
Intel i7 4790k / MSI Z97M / Hyper 212 Evo / MSI Twin Frozr GTX 770 / 16GB Corsair Vengeance 1600MHz / Fractal Design Arc Mini R2 / Corsair CS750M / Samsung 840 Evo 250gb SSD /  WD Blue 1TB
https://linustechtips.com/topic/111983-double-posting-issues/
Correct me if I'm wrong but I think that this issue has been there for a long time, I believe they are working on it
What always works is if you google search your topic but put Linus Tech Tips at the end of it
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/111983-double-posting-issues/#findComment-1497244
Thanks,
Blueprint
I think it'd be great if we got a warning where it alerted us "Topic previously posted by (insert example name here). Would you like to repost topic? Warning: it may be considered as spam!"
My n00Build http://pcpartpicker.com/user/NameOfNoInterest/saved/
Do you really expect me to know things?
$25.67/$~2500 (Price changes hourly..) I'm 1/100th of the way there!
https://linustechtips.com/topic/111983-double-posting-issues/#findComment-1497245
Yeah Google is the best.
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/111983-double-posting-issues/#findComment-1497264
Always google "linustech <insert topic here>" before posting
Ah ok cheers.
https://linustechtips.com/topic/111983-double-posting-issues/#findComment-1497275
Use this:
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/111983-double-posting-issues/#findComment-1497276
The search function on IPB is broken, and they're probably going to wait till the next version of it fix it.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/111983-double-posting-issues/#findComment-1497631
The best thing to do currently is to just google your topic with the word "linustechtips" (without the quotes) in it. Would be great if it had a feature like XDA where it gives related topic titles when you type in your thread title.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/111983-double-posting-issues/#findComment-1500293
