Okay. So I just put all my parts into a Rosewill Prism S, right? Fans are kinda loud but whatever. My problem is suddenly my 4tb hard drive has decided to make loud "scratchy" sounds when its under load. I'm hoping its just the Hard drive sitting on bear metal rather than failing.
Just here for some fun.
PC Build 1: Great Ape (Main Rig) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/nKjHGX
CPU: Ryzen 3700X
GPU: ASUS GTX 1070Ti 8GB ROG STRIX
PSU: SeaSonic FOCUS Plus Platinum 750 W
Mobo: MSI MPG B550 GAMING CARBON WIFI
Case: Corsair 4000D
PC Build 2: Piccolo (Emulation/ITX/Transportable) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/tDBdHx
CPU: Intel i5-11400
GPU: EVGA GTX 1060 3GB SC
PSU: EVGA SuperNOVA GM 550 W
Mobo: ASRock Z590M-ITX/ax
Case: Silverstone RVZ03
♪♫ "2-to the-1-to the-1-to the-3 I like good OC and RGB. Configure so much, you wouldn't believe. And I get more blue screen than a Walmart PC" ♪♫
https://linustechtips.com/topic/1119296-my-hdd-noise/
Pull it from it's mount and see if it still makes noise.  You should back it up or copy the files off now....
https://linustechtips.com/topic/1119296-my-hdd-noise/#findComment-13011695
Actually, I just used Crystaldiskinfo to record the noise. It didnt give me any warnings. So under load it sounds like this (it gets worse near the end)
And When its just on standby it makes like a rhythmatic ticking. Same spacing, same noise, same volume.
help.mp3
CPU: Ryzen 3700X
Case: Corsair 4000D
CPU: Intel i5-11400
https://linustechtips.com/topic/1119296-my-hdd-noise/#findComment-13011729
Backup now!!!!11!!!11!!
https://linustechtips.com/topic/1119296-my-hdd-noise/#findComment-13011734
Just did. Put it on a spare i had
CPU: Ryzen 3700X
Case: Corsair 4000D
CPU: Intel i5-11400
https://linustechtips.com/topic/1119296-my-hdd-noise/#findComment-13011741
