Hi,
I am using GateOne for my school project as a terminal, and I want parsing in the terminal.
The current code I have is this:
 var rmWarning = function() {
    console.log(GateOne.Terminal.Input.commandBuffer); // So you can see what's in the buffer (for debugging)
    if (GateOne.Terminal.Input.commandBuffer.indexOf('rm -rf') != -1) { // "if the command starts with 'rm -rf'..."
        GateOne.Visual.displayMessage("You're about to execute a very dangerous command.  Press Enter again if you're absolutely sure you want to execute it.");
        GateOne.Terminal.Input.charBuffer = []; // Empty the character buffer so the enter key doesn't get sent
GateOne.Events.on("terminal:enter_key", rmWarning);
What that basically does is if the terminal detects rm -rf it will display a message saying that this cannot be executed.
What I want to do is delete that command, the user inputs.
The Gateone.Terminal.Input.charBuffer = []; allows me to input text into the terminal, so if I input ["test"], when the user hits enter the word test is shown.
So what I am struggling with is how do i execute Ctrl-C or even a bunch of backspaces?
Any help will be appreciated.
Thank you. :)
https://linustechtips.com/topic/111927-gateone-javascript-help/
