I was curious if it's recommended to re-paste every time a processor is detached from its cooling source, such as a processor tower/cooler/heat sync and/or a graphics card cooler?  Any useful info would be appreciated  ?
Primary
OS:        Windows 10 - Professional (64-bit)
CPU:      i9-10900k 3.7-5.3GHz (10th gen)
GPU:      EVGA RTX 3080ti FTW3 Ultra Gaming 12gb
MB:         ASUS RoG Maximus XIII Hero (ATX)
RAM:      64gb (4x16) DDR4-3200MHz G.Skill TridentZ Silver/Black (CL16)
HD:         1x 8TB Corsair MP400 NVMe PCIe 3.0 (SSD)
               2x 16TB Seagate Exos 7200rpm (HDD)
E-HD:     12TB WD
PSU:       EVGA 1000w G2, 80+ Gold (modular)
UPS:       900w CyberPower
Display:   ASUS 27” 1440p/270Hz IPS 0.5ms (XG27AQM)
                Aorus 27" 1440p/165Hz IPS 1ms (FI27Q-P) iGPU
KeyB:      EVGA Z15 (wired)
Mouse:    Logitech G-502 Hero (400/600/800/1000)
Headset: JBL Quantum ONE Gaming Headset
Case:      Cooler Master MasterCase H500P Mesh (ATX)
Other:     XB-1 Wireless Controller Adapter w/Controller
              NPET H01 Gaming Mouse Bungee Cord Holder w/4 USB Ports
Gaming Computer Specs.pdf
https://linustechtips.com/topic/1118628-thermal-paste-recommendation/
Repasting is good practice but the difference is often very small as long as the paste isn't old or otherwise disturbed like being smeared off.
It's recommended, because otherwise you can trap air bubbles.
Consider a thermal pad. I started using this one several months ago and my CPU temps are equal to a dozen different pastes I have used. Even Linus and other YouTubers have recommended it and you see them using it all of the time in order to quick swap CPUs without having to deal with paste. Seriously, the performance is incredible. I'm currently running my 8700k at 5ghz on all cores with a nice air cooler and this pad and my temps are fantastic! I've taken my cooler off three or four times to move parts around and the pad comes out and goes right back in like it's nothing!
https://www.amazon.com/Innovation-Cooling-Graphite-Thermal-Pad/dp/B07CKVW18G/ref=sr_1_4?keywords=thermal+pad&qid=1572410795&sr=8-4
Is the 30x30mm for Intel and the 40x40mm for AMD?
Primary
E-HD:     12TB WD
Yes, although I've seen people use the 30x30 for AMD and reported it cools just the same. But, yes, 30x30 Intel and 40x40 for AMD would be typical.
2 minutes ago, Joey-Joe-Joe said:
I use the 30x30 on my 8700k and it fits perfect.
Thanks - I'm about to order parts w/a friend tomorrow for his $2k computer and I was wonderin which one I should get for it (i9-9900KS).  I have the i7-8700k (in description), so I am thinkin about purchasin one when I upgrade to the new black edition Noctua dual fan.  Once I get it, then I'll likely just Sync All Cores for more consistently higher frame rates.  The Cooler Master Hyper 212 - Black Edition isn't anywhere near cool enough for the processor and it gets to dangerous lvl's (104 f)
Primary
E-HD:     12TB WD
did you mean celsius? because 104 C is not good, but 104F is fine
Don't forget to use the "Quote" feature or mention me ( @Gegger) if you want me to see your reply!
Community Standards // Forum Quickstart Guide // Floatplane // Forum FAQ // The Parrot Gang
Banned by Linus in the "banning game" thread who added insult to injury by putting this crap in my sig >(
WE ARE THE DARK SIDE Don't be a light theme peasant
             ........:oo:........
           o//ssssssssyhhysssss+////o               .''''''''''''''.
          mddmmm/::ddddddddddddddmmmyss::/mmN       |   PARTY ON   |
          o..+oodddmmmhhhhhhhhhhhdmmmmmdddooy       | ,............'
         h::oyyhddmmm+++///////////++++++mmmddy::s  |/
      Nyyo[[sddhyyyyy::::::::::::::::::::yyymmh//oyym
     h..:oohmm+:://///::::////////////////+mmmmms..sNN
     m++sddmmm+::hddhhy::+ddddddddddddddhhhmmmmmdhh+++d
    Nsssyyhmmhssooodmmhhh::+mmdyyyyyyyyddddddmmmmmmmmo::d
   mmd../mmmmmo::shhdmmhhh::+mmhooooooooyhhmmmmmmmmmmmyssdmm
  +++++smmdddo::///dmmhhh::+mmhooooooooooommmmmddddmmmdd/++m
 ``+hhhmmhoo/:::::oooooossymmhooooooooyyymmdoooooydddmmo//N
 ++:mmmmmy:::::::::::::/yyhmmhooooooooyhhmmd:::::+yyhmmyssddd
ooommmmmy:::::::::::::://ommhooooooooooommd:::::://shhdmm+..
yyhmmh++/::::::::::::::::+mmhooooooooyyymmd::::::::/++hmm+//
dddmmh++/::::::::::::::::+mmhooooooooyhhddh:::::::::::hmmysshhd
mmmmmdhhs::::::::::::::::+mmhoooooooohhhhhy:::::::::::hmmhhh``+
mmmmmh++/::::::::::::::::+mmdhhsooooodmm++/:::::::::::hmmsss``+
dddmmhoo+::::::::::::::::+dddddyssyyydmm::::::::::::::hmmsoo++o
dddmmdhho::::::::::::::::+hhdmmddddmmmmm::::::::::::::hmmsooNNN
mmmmmh///::::::::::::::::+hhdmmmmmmmmddd::::::::::::::hmmsoo++/
yyhmmdss+::::::::::::::::/ooydddmmmmmsoo::::::::::::::yddhyy::+
++ommmmmy:::::::::::::::::::ohhdmmddd/::::::::::::::::shhdmmsssNNNmmN
..+mmmmmy:::::::::::::::::::://shh+//:::::::::::::::::://dmmmmdoo+..o
``+dddmmhss+:::::::::::::::::::+++/::::::::::::::::::::::ooodddhhysshNNy++m ``+hhdmmdhhs///:::::::::::::::::::::::::::::::::::::::::::::yyymmmmmmmmo++hNNmdd ``+hhdmmdhhhhh+:::::::::::::::::::::::::::::::::::::::::::::::/hhhhhdmmmmmsoo... ``+ddmmmdhhhhhyyyyyyyyyyyo:::::::::::::::::::::::::::::::::::::+++++sdddmmdhhsss//+ ``+mmmmmhsshhhhhhhhhhhhhhy++/:::::::::::::::::::::::::::::::::::::::+ssyyydmmddd///hhd ``+mmmmmy::shhhhhhhhhhhhhhhhs:::::::::::::::::::::::::::::::::::::::::::::ymmmmmmmh../ ``+mmmmmy:://////////////ohhhyy+::::::::::::::::::::::::::::::::::::::::::///hddmmmhhs++s ``+mmmmmhssssssssssssssssydddddysssssssssssssssssssssssssssssssssssssssssssssdddmmmmmy::s ``+mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmhooh
Yes, Celcius - I was amazed it didn't thermal throttle/crash/BSoD
Primary
E-HD:     12TB WD
Ah, ok, that's not good. If you haven't repasted already, do that
I just turned off Sync All Core and it's stable now - I'm not goin to stay boosted at 4.7GHz until I have the new Noctua black edition; then I should be fine.
Primary
E-HD:     12TB WD
Are you oc'ing or running default motherboard settings? The Hyper 212 BE on a stock 8700k or 9900k should be fine for keeping temps in check.
For leaving Asus MCE enabled or oc'ing, you should get a better cooler.
Just w/e the motherboard has w/Sync All Cores to 4.7GHz.  It's fine when they're on Auto, which's what I have it on now; but the constant 4.7GHz overheats it immensely w/only 4 heat pipes, thus far.
Primary
E-HD:     12TB WD
At stock, Asus MCE is enabled which is basically an auto-oc which also tends to use more voltage than manually oc'ing. That's probably the cause of your high temps.
Try disabling it and see if that helps.
Should performance change at all?  The only real BIOS thing I change is MBR and RAM speed, so I'm not majorly familiar w/OC, voltage, etc. or anything to that degree.
Primary
E-HD:     12TB WD
Yes, Asus MCE is basically an auto-oc and oc'ing will increase performance. Turning it off would remove that but you can probably manually oc using less voltage for similar results and lower temps.
I wouldn't know how to adjust the voltage, so it's not a major interest/past time of mine.
Primary
E-HD:     12TB WD
Alternatively, you could just leave it at stock after disabling MCE. If all you're doing is syncing the cores to max turbo, leaving it on doesn't provide any benefit.
My temps have gone up about 10-15c w/out MCE on at Auto  =/
Primary
E-HD:     12TB WD
So MCE is set to disabled? How are you testing for temps?
Yes - I'm playin the normal games I play w/cold ambient temps (window open w/an overhead fan)
Primary
E-HD:     12TB WD
Games aren't a very consistent way of testing temps. I recommend using synthetic loads like OCCT instead.
I know they're far from consistent, but it's the vast-majority of what I do w/it; so it's pretty much the only thing that matters for what I'm lookin for.  A handful of games are played heavily on it, so those're when the temps'll matter the most to me.  Everything else is goin to be irrelevant, since it won't be under load.  I'm movin 11/5, so I'll have to see what the ambient temps are there.  Also, humidity in case it's an issue.
Primary
E-HD:     12TB WD
What are temps during gaming? As long as they're kept in check, that's all that really matters.
