You can expect 90plus degrees during load. I would sell the thing and get a better solution
Country? Budget?  Sample retailer or shop?
Case, RAMs,mobo?  To make recommendations easier
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1117793-wraith-prism-cooler/#findComment-13000057
You can see some examples here: https://pcpartpicker.com/builds/by_part/QKJtt6#h=1
https://linustechtips.com/topic/1117793-wraith-prism-cooler/#findComment-13004617
Most seem to go above 70c. I know thats exceptable, and will keep for awhile but definitley getting aftermarket.
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/1117793-wraith-prism-cooler/#findComment-13005645
Question: Would a 120AIO be better, like Corsair or CoolerMaster?
https://linustechtips.com/topic/1117793-wraith-prism-cooler/#findComment-13006856
It can be.
Depending on what your goals, it might be a good option and / or there may be better alternatives.
https://linustechtips.com/topic/1117793-wraith-prism-cooler/#findComment-13006882
There's a couple of videos that do focus on this matter you have at hand.
Might be worth checking out
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1117793-wraith-prism-cooler/#findComment-13006912
Have a prism on my 2700X (stock speeds). Note the prism cooler has a toggle switch to choose between low and high fan speed modes, i keep mine on low. I have the fan set on 50% from 0 to 60 degrees, then a straight gradient to 100%  from 60 to 75 degrees.
Idle temps range from about 40 to 50 degrees. Max load (Cinebench etc) get its up to 76 degrees with the CPU boosting to ~4GHz on all cores and pulling ~120W
During gaming it sits around the high 50s to low 60s (My main game is warframe, not very CPU intensive so YMMV)
I also have a Masterliquid ML120 RGB which i used to run on it, with dual fans in push pull exhausting air. Temps were slightly better but basically identical. peaked at 75 degrees (obviously took longer to get there) Idled around 42-45
Stuck with the air cooler for simplicity
I'd say you need to get a 240 AIO to make the performance difference worth it, the prism is a half decent air cooler already so a 120 AIO is barely any better
Ryzen 7 2700X  | Gigabyte RX5700 XT | ASUS TUF B450M | HyperX Fury 2x16gb 3200MHz |  CM MasterBox Lite 3 (Mesh Modded) | Corsair MP510 960GB | Be Quiet Pure Power 11 700w
https://linustechtips.com/topic/1117793-wraith-prism-cooler/#findComment-13008584
Running a stock 3700X, with good case cooling mine gets to 72 degrees max when running a blender and heaven loop, I think the fan only hits about 2600 rpm like this and is OK for noise.  I'm sure I could run it cooler at the expense of noise.  Before I had the case fans sorted I would get up over 80 degrees with the fan screaming loudly at max (3200 rpm).  When gaming the system barely makes any noise, haven't logged temps but the fans barely speed up.
IMO the Prism is totally fine if your willing to put a bit of effort into case cooling and running stock speeds, might work for a mild overclock.
https://linustechtips.com/topic/1117793-wraith-prism-cooler/#findComment-13008724
