Can i plug a 3 pin addressable rgb into a 4 pin addressable rgb on my mobo?
Solved by TheSLSAMG,
19 minutes ago, Turtle Rig said:-snip-
You can't. 3-pin ARGB headers are 5V with a 5V pin, a single data pin, a blank spot and a ground pin. 4-pin RGB headers are 12V with 12V, red, blue and green pins. Plugging an ARGB strip into a non-ARGB header will blow out the strip.
BPS Customs did a video testing this out.
