hi Guys
I dont know if its the right section for the post but... anyway ill try my luck .
So I recently bought the Phanteks P350X and am thinking about which CPU fans / case fans should I buy or where to place them.
I've seen in the LTT video what is all so possible and what setup what a difference can make.
Still, I'm still pretty unsure what exactly is best for the following RIG:
Case: Phantek's P350X
CPU: Ryzen 5 2600 6x Cores
(if more is to ask just look at my profile because everything is detaliert)
It is now only the question of whether I should get me an AIO or just full air cooling. And which fans are best for the case.
Thanks in advance
(edit): would be nice to somehow sync the lights all together on the mobo/software
Edited by GhostTownParty
https://linustechtips.com/topic/1116636-new-cpu-and-case-fans-for-new-case/
5 minutes ago, emosun said:
does this mean you are only looking for rgb fans?
Then i have to ask you:  Do you know how the following Case actually looks like ? "Phanteks P350X" If yes, then maybe i could go RGB. Otherwise its not important. Depents on how much i have to pay extra for a set of non/rgb fans.
And can i sync the fans with the light stribes on the P350X lights with them together too?
3 minutes ago, GhostTownParty said:
its not important.
good because I'd just recommend some good old brown and beige noctuas. should keep the machine quite cool and be decently quiet . I also don't think you'll be needing an aio for the cpu.
Are you now talking about only the CPU or for the whole case?
On 10/24/2019 at 2:20 AM, brob said:
Need to know the motherboard to address this.
I have a B450 MSI A-Pro Mobo.
I actually now have a Phanteks P350X Case now and im quite happy with it. Now is the question, i want on top 2 120mm and a rear exhaus 120mm Case Fan and I want to Sync these with my Phanteks Case LEDs with them over the MSI Mystic Light 3 Software. Is it possible in anyway ? No Paywall here.
17 hours ago, brob said:
i don't believe that the motherboard does has a compatible rgb header.
I'm about to get those :
Cpu Fans
Case Fans
Cant I just daisy chain those all with the included controller of the 3er Fans pack with the with the CPU fans ?
