Those temps are great. Nothing wrong with them. Sounds like you have your cooler mounted properly and no need to attempt to tighten it down anymore.
"Black Out"
Dedicated Streaming Rig
Temps looks perfectly fine and overtighting your CPU cooler can actually damage it so just leave it as is.
Personal Desktop":
Luna, the temporary Desktop:
I was expecting much higher temperatures with the stock cooler.
Nothing wrong there.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD0: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
1 hour ago, Privatech said:
My mistake i was testing with Minecraft cause Apex was still downloading. Idle temps are around 43 degrees and around 68 degrees when gaming
68 is still well within spec so I would leave it as is, I doubt you would get lower by any significant margin by tightening or remounting your cooler. The 7nm chiplet design is actually quite hard to keep cool so even with a good aftermarket cooler there will be limited improvement in thermals as the boost algorithm uses up any extra headroom
edit: I would probably download something to stress test with to see how temperatures do under 100% load eg Cinebench and test for peak temperature there, just to be sure you aren't going to hit thermal limit under extreme cases
