Hey, I have already made a post surrounding this issue but I have some new information that I feel might make a new post more helpful.
Current build:
Rx 5700 XT rog strix
i5 7600k
Asus z270 prime p
Corsair rm650x
The i5, mb and psu are around 2 years old at this point.
My issue is that my new Rx 5700 XT has some insane coil whine when under load, in UserBenchmark for example it sounds like it's about to blow up.
The reason I suspect that this is caused by the motherboard stems from a couple of reasons. Firstly I have tried switching gpus, my now old rx 480 was the gpu that I first started noticing the whine from and I tried using my older r7 370 that had similar whine and now my Rx 5700 XT is also doing it. Secondly, when I was still using my rx 480,I tried switching my psu out for my friends and I still had the same issue but when I actually installed it into his pc with his mobo I didn't notice the whine at all. Lastly, the whine started after I tried bumping up my Cpu clock to 5 ghz with limited results and when I went back to 4,7 ghz I noticed the whine which I had never heard before.
The reason I am conserned is because the coil whine during gaming is insanely loud and seems to be getting louder with each session and I worry I am actually damaging my new gpu aswell.
So is my best course of action to buy a new motherboard similar to my current one and hope that it solves the problem or could it be caused by my cpu aswell?
https://linustechtips.com/topic/1116040-gpu-coil-whine-caused-by-motherboard/
Is it possible it's the PSU that has coil whine? My CX550M has coil whine whenever I stress the GPU, it took a while to narrow it to the PSU since it started happening after I got a new more power hungry GPU
I firstly tried switching gpu with my buds and in his pc it didnt seem to make any noise at all, might have to test it again to be completely sure but it wasn't even close to as loud. I also tried just switching psu but the whine was still there.
I do feel it's weird that my gpu got the whine just after I tried to up my cpu oc since I dont see how that could affect my gpu power delivery
