Are a couple of slightly bent pins gunna be an issue?
Go to solution Solved by Radium_Angel,
7 minutes ago, AtraisMachina said:
Is my anxiety warranted?
AS long as the pins didn't physically break you, you are fine.
I was building a computer yesterday and idiotically handed the naked cpu to my inexperienced friend, and he very slightly bent 3 pins on the outside of the chips. The ryzen 3400g did not go into the socket properly (it stuck a little on one side) but with a little fiddle and force it went in. I pulled it in and out a few more times just to make sure it didn’t break and to kinda bend the pins back with the socket.  Anyway it booted and I got an os loaded tested the temps were all good.
So my question is, is this going to cause issues at some point even though it booted? Are there any tests that I should run to confirm the chip is operating properly? Is my anxiety warranted?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Just now, AtraisMachina said:
Thank you my anxiety went down 10 points lol
No problems.
Now those pins are slightly weaker than the other ones, so I wouldn't make it a habit of pulling the CPU out and putting it back in the mobo. But beyond that you are a-ok.
I've dropped a ryzen cpu before and bent like 20 pins. I was able to bend all the pins back with paper clips, tweezers, and a credit card. I got them straightened out and the CPU worked fine then. The best trick I learned was placing a credit card in the line of pins and kind of pushing gently against the pins to get everything lined up again.
That CC is a good idea if you end up bending pins, stealing this idea just incase.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
I had accidentally bent a couple of pins (maybe even 3 or 4) on my Z87 mobo some years back when I was building my i7 4770K rig, I gotta admit I was pretty careless due to overconfidence. Took a long nose tweezer and straigthened the bent pins and installed the CPU, no problemo. It's still running great as my multimedia HTPC rig.....
Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS)2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2
