My iPhone 7 won't turn on I've tried holding down the power down button and power button and it doesn't work. It was charging overnight and when i woke up just didn't work. I've replaced the battery so it cant be that. I think its the black screen of death. Does anyone know whats wrong/any ways to fix this?
CPU: Ryzen 5 2600 @ 3.2Ghz
Motherboard: MSI B450 Gaming Pro Carbon AC
RAM: Team Vulcan DDR4 16GB (2x8GB)
GPU: Zoatac Gtx 1070 8GB
Case: CoolerMaster Masterbox Lite 5 RGB
Storage: 2TB Toshiba HDD, 120GB WD Green SSD
PSUGigabyte P650B
https://linustechtips.com/topic/1114740-my-phone-wont-turn-on/
WHY DO PEOPLE YELL IN TITLES?
The iPhone 7 does have a component level issue that can cause bootlooping and black screens. Does the phone show up in iTunes? What happens when you plug it in to a PC?
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1114740-my-phone-wont-turn-on/#findComment-12975583
It doesnt show up on itunes and when i plug it into the pc its the same as it not being plugged it. The pc doesnt recognise it either
PSUGigabyte P650B
https://linustechtips.com/topic/1114740-my-phone-wont-turn-on/#findComment-12975623
13 minutes ago, Bob116 said:
it's iphone 7 bendgate
what does that mean
PSUGigabyte P650B
https://linustechtips.com/topic/1114740-my-phone-wont-turn-on/#findComment-12975626
iPhone 7 was not a "bendgate" phone... That was the 6/6s, specifically the plus models.
Sounds like the known default with IP7 boards then, a well versed board repair specialist like Louis Rossman can usually fix it.
what does that mean
"Bendgate" refers to an issue with the iPhone 6, 6s, and their respective plus models, that had a tendency to bend due to poor internal design. This REALLY only affected the plus models.
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1114740-my-phone-wont-turn-on/#findComment-12975661
do you know where i can do this and how much it would cost?
PSUGigabyte P650B
https://linustechtips.com/topic/1114740-my-phone-wont-turn-on/#findComment-12975680
^^^ Even then, the 6 Plus I used to run is only slightly bent, and my 240+ lb ass sat on it a good few times. IIRC the main issue was the aluminum they used, it's very very soft, bends pretty easily (more so if you remove the screen, the glass does add a good bit of rigidity).
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
https://linustechtips.com/topic/1114740-my-phone-wont-turn-on/#findComment-12975685
Really the issue is that the frame (atleast on the 6s) is just a flat piece of aluminum internally. There is no structure to support it, only by the PCB and display.
That depends on the shop you go/send it to.
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1114740-my-phone-wont-turn-on/#findComment-12975883
OKAY ty
PSUGigabyte P650B
https://linustechtips.com/topic/1114740-my-phone-wont-turn-on/#findComment-12975897
