Hello!
Basically I have overclocked my i7 9700K to 5.2 GHz at manual 1.420 voltage. It seems stable but will have to stress-test it a lot more. Though one thing I have noticed is that I only get a multi core score of about 3700 in Cinebench r20... I have seen people getting over 4100 points with their i7 9700K at 5.2 GHz.
Does anyone know what the problem might be? All feedback is appreciated! Thanks.
Corsair iCUE 4000X RGB
ASUS ROG STRIX B550-E GAMING
Ryzen 5900X
Corsair Hydro H150i Pro 360mm AIO
Ballistix 32GB (4x8GB) 3600MHz CL16 RGB
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Gigabyte RTX 3060 Ti GAMING OC
Corsair RM850X
Predator XB273UGS QHD IPS 165 Hz
iPhone 13 Pro 128GB Graphite
https://linustechtips.com/topic/1114653-low-cinebench-r20-score-with-9700k/
2 minutes ago, Gameking002 said:
are you sure you're running 5.2 Ghz?, because cinebench seems to detect 3.6.
Yes but Cinebench always reports the stock clock speed which is 3.6 Ghz. HWMonitor says 5.2 GHz during the full run :)
Ryzen 5900X
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Corsair RM850X
Run with monitoring software at the same time so you can see if you are throttling, etc - this is an SS I took last night while trying to hit 4.2ghz run - I agree that Cine should see the OC as well.  EDIT - don't just my score, that's without OCing the ram for CPU stability.  Best run is 3956 and have that SS too ;)
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
No, Cinebench 15 at least shows stock clocks...
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
I always run it with HwMonitor and CPU-Z open. I have got no throttling, it stays at 5.2Ghz during the whole run and max temp is 88 degrees Celsius.
Ryzen 5900X
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Corsair RM850X
From what I can tell you are not running @5.2 from the Screenshot. CINEBENCH 20 has done that to me as well, just make sure it says 5.2 in Windows control panel at minimum. I have a 3156 on an R52600 @4.2 so you should definitely get  better than that at your specs
I find it odd, was discussing this yesterday, CineR15 and R20 have always shown my OCs.
@OP if you aren't hitting the runs that other people are you need to check task manager, make sure nothing else is running.  Close out any startup programs.  You can also set the affinity in task manager to Real Time for a couple more points (just learned this last night) and can push majority of the screen "off screen" for more points. (just learned that last night, haven't tried either trick though)
Okay, you mean Task Manager? I just went to the gym but will check it with Task Manager when I get home so I’m back with the results within 2 hours!
Ryzen 5900X
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Corsair RM850X
Tried it again with task manager open to check the core speeds and disablede every startup program. It was running at 5.2 Ghz during the whole run and this time the score was about 100 points higher, 3800. It is still quite far away from the 4100-4200 that I have seen other people get with the 9700K at 5.2 Ghz...
I just did the math and realized that something might be wrong with on of the cores on the CPU... If you look at the picture I included at my first post, the Single-core score is 534 and multi-core score is 3723. If you take 534 x 8 = 4272 which is the score I should be close to considering I have got 8 cores and the single score is 534. 534 * 7 = 3738, is about the same as the score I got. It kinda seems to me like only 7 cores out of my 8 work properly considering that my single-core score multiplied with 7 is my multi-core score... Also if you look at my MP Ratio, it is 6.98 x and shouldn't it be closer to 8 x considering my CPU got 8 cores? With other peoples tests they seem to have a MP Ratio of about 7.62 x, and @jstudrawa have a MP Ratio of 7.68 x. To me it seems like one of my cores is broken, but is that even possible?
Ryzen 5900X
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Corsair RM850X
Don't use me as an example, as the 8700K is 6 cores but with 12 threads, so my ratio won't be like yours.  Try to find other 9700K runs and see what they get.
It's not an exact multiplier.  1 core x 8 for example.  Programs don't use all cores the same. In a perfect world, yes.  But in reality, no.
OnePlus Ecosystem:
Other Tech:
Oh, didn't think about that. Though what I have found is that most 9700K seems to have a ratio of about 7.55-7.7 x so something is weird with mine...
Ryzen 5900X
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Corsair RM850X
When you run Cinebench, watch the Task Manager or HWInfo or GPU-Z like I had up to see each cores performance.
OnePlus Ecosystem:
Other Tech:
Yeah, that is what I'm doing all the time. Every one of the cores operates between 5198 MHz - 5203 MHz.
Ryzen 5900X
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Corsair RM850X
In Task Manager tho, for example, it has a utilization graph as well.  maybe one core isn't running 100% like the others?
OnePlus Ecosystem:
Other Tech:
Fof reference my 5ghz 8700k gets just over 4000 points in R20
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
Gah, now I have to download C20 and see how mine fares :P
OnePlus Ecosystem:
Other Tech:
Mine might be lower now.
I did it a few months ago, but I I had the most up to date micro codes and stuff at that time.
Micro codes?  I just have mine on the BIOS Profile for 5.0GHz, so it's not optimized all that far I don't think.
OnePlus Ecosystem:
Other Tech:
Yeah I meant BIOS updates.
Here's the last one I did at 3995 at 5ghz and 4065 at 5.1
I've got better results and I swear I posted them somewhere but whatever around 4k margin of error
I also think this is weird, but CB has never showed my OC's.  I only OC my intel rig, so maybe there is something to that?  I let ryzen ones run at stock.  But my CB's have always reported the base clock only, never the OC.  The scores always reflect the OC though
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
They are all running at 100%, though this time I actually got a score of 3890! Though that is still about 300 points lower then what I’ve seen other people get...
Ryzen 5900X
Samsung 980 PRO 1TB
Samsung 970 EVO 1TB
Corsair RM850X
When you run CINEBENCH is it installed or are you running it just from the .EXE itself? When I install it, it will recognize what GHz I am running. Right now I ran it just from the .EXE and it is not installed and no matter what I do it still says I am running stock 3.4GHZ, when I know I am running at 4.2GHz @37c idle, lowest idle @20c, MAX Temp @70c running CINEBENCH. AMD RyzenMaster, MSI Command Center, CoreTemp, and Performance Monitor all say 4.2GHz. Odd part, System says, 3.4Ghz. Programming is only as smart as the programmer, damn Humans.
Can just simply be your memory installed performs different then the one others had used.
OCing my memory and tightening timings, just a lil bit not until perfection, gave me a 150pt plus.
Btw, CB20 shows my ryzen 2600 OC when testing. :D
