Cooler Master RS-600-ACAB-M2 PSU
Solved by Keyboard Basher,
After checking Cooler Masters list of Haswell supported PSU's, the Elite Power200 (The one in your post), it is "Not Haswell Ready". But that's because it doesn't support the C6/C7 CPU states. The only drawback of not using a Haswell Ready PSU is that you would only save 2 - 3 Watts instead of 5 Watts when the CPU is idle. Not a huge drawback. Have your friend disable the C6/C7 power saving modes in his BIOS.
Here is the official Cooler Master Haswell Ready PSU list:
http://coolermaster-usa.com/press_release/haswell/haswell.html
