ok i have not keep up with text so im reading everything and asking advice.  my build has
Rosewill Cube Mini ITX/Micro-ATX/ATX Mid Tower Gaming Pc
Rosewill Glacier Series 700W Modular Gaming Power Supply
ASRock Z390 Phantom Gaming 4 LGA 1151 (300 Series) Intel Z390 SATA 6Gb/s ATX Intel Motherboard
Cooler Master MasterLiquid Lite ML240L RGB AIO CPU Liquid Cooler, Sleeved FEP Tubing, Dual 120mm RGB Air Balance
Intel Core i7-8700K Coffee Lake 6-Core 3.7 GHz (4.7 GHz Turbo) LGA 1151 (300 Series) 95W
G.SKILL Aegis 8GB 288-Pin DDR4 SDRAM DDR4 2400 (PC4 19200)
MSI GeForce GTX 1050 Ti DirectX 12 GTX 1050 Ti GAMING X 4G 4GB 128-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready
Hitachi Ultrastar 7K3000 HUA723030ALA640 3TB 7200 RPM 64MB Cache SATA III 6.0Gb/s 3.5in
samsung 250gb ssd
Crucial P1 1TB 3D NAND NVMe PCIe M.2 SSD
24 inch 144hz spectre curve monitor
i know the video card need to be upgrade was looking at 1080 ti should i just save up go for 2080 ti?
other then that what should i upgrade first?
did not think of a budget just looking for so not high dollar but not cheap so midrange budget
https://linustechtips.com/topic/1114227-help-upgrade-my-pc/
Uh...nothing. Except that video card. I'm not sure why that POS is in there.
Personally I'd go with the 2080 Super. The 2080Ti isn't really worth the almost doubling of the price.
Welcome to the forum.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1114227-help-upgrade-my-pc/#findComment-12971026
so buying a 2080 is worth saving little more over a 1080?
https://linustechtips.com/topic/1114227-help-upgrade-my-pc/#findComment-12971038
The 1080 Ti isn't really sold new anymore. So you'd be looking at buying used? Or?
https://linustechtips.com/topic/1114227-help-upgrade-my-pc/#findComment-12971043
1 minute ago, Phillipferguson said:
retired army midrange lol
well I'll just go ahead and wait and see how long it take for you to type an actual number as one of my army guy friends just bought a porshe a few months ago
https://linustechtips.com/topic/1114227-help-upgrade-my-pc/#findComment-12971076
That means nothing to most people so...
ya was looking on newegg at refurbed
I wouldn't get a refurb personally. Unless it was a considerable discount.
Right? A Private gets a much different package than a Rear Admiral...
https://linustechtips.com/topic/1114227-help-upgrade-my-pc/#findComment-12971086
ok dude i give up i am fully disable retired so 4k a month income budget work for u.
i hate dealing with smart a ppl
https://linustechtips.com/topic/1114227-help-upgrade-my-pc/#findComment-12971089
I'll try my best to not be annoid.....
but can you just type a number that is the maximum amount of money you have to allocate to a computer upgrade.
Don't need to know where you worked , or if you're retired , or what your total monthly income is , or need to see your tax returns , or need to know how much you hate dealing with people who literally are asking for a budget so they know what to pick for you.
https://linustechtips.com/topic/1114227-help-upgrade-my-pc/#findComment-12971098
yeah not trying to be rude man, not trying to rush you in any way but emosun and dizmo are right, we need a budget in order to make any sort of reliable recommendation.
You need to be much more specific with these types of questions, especially with computers. They have too many different factors to be general.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1114227-help-upgrade-my-pc/#findComment-12971161
