Can i limit Speed and bandwidth of Wifi Users?
Tech Lover
hi. as the topic states it clearly, i m in search of a program or anything by which i can limit the speed and bandwidth usage of users on my wifi.
my net is dsl and when im gaming my brother uses and my ping goes around 500ms from ~100ms!!!  and after that i get kicked. im so mad and so frustrated that i cant bear it anymore!
so can anyone help me and tell me what softwares or any method should i use to limit the speed that wifi users can avail at maximum from my internet and also limit the monthly bandwidth data for these users?
my current wifi router is Asus RT-N10+. i might also change my router even if i have to get this done.
pls assist.
thanks
Current Rig: Intel core i7 4770K Stock 4.5G, Asus Maximus VI Hero, Corsair Vengeance 1600Mhz 16Gb (8Gx2), 2x SLi Gigabyte Geforce GTX 670 2Gb GDDR5 3X Windforce Edition, Corsair Hydro Series H100i (Push), JDS LABS O2/ODAC combo, Fiio E18 KUNLUN, Asus Xonar Essence STX (secondary PC), Sennheiser HD700, Hifiman HE 400i, Beyerdynamics DT 990 PRO 250 Ohm, Sennheiser HD 518, Cooler Master Silent Pro M2 850W 80+, Cooler Master CM 690 II Advanced, Samsun4g DVD R/W Combo, 3X Cooler Master 120mm Blue LED fans, LG IPS 23EA73, Logitech G710 BLUE, BlackWidow Ultimate 2013 Edition,Logitech G402 HYPERION FURY, Bloody Core V7, SteelSeries QcK Mass MiBR mouse pad
You can, but in my opinion you should only do this if you are paying for the internet.
you can set QoS and make your own packets highest priority
YES im freaking paying every penny for this!!! they dont help me in paying the freaking monthly bill or Rs 5000 which is about US $48!!!
can u tell me the method to do this? or any software for this?
your router should have this feature check it by going in to its web management
http://www.wireless-home-network-made-easy.com/qos-packet-scheduler.html :)
still no solution man , thats for the Linksys routers. mine is Asus. and the options that are listed are not in my router settings. i have checked.
is there any software for this?
Netlimiter
has to be installed on their machine , so they can stop the service if they know how.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Your router should have an option somewhere to limit WiFi bandwidth. I think NetWorx might be able to do that to, as well as set quotas (what I use it for). Give it a look. http://bit.ly/NetWorxBand
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
So with this software can i limit the speed of clients as well? and also what about the mobile devices? can this software limit the speed on mobile devices connected to my wifi aswell???
  • 1 year later...
Hello, did you manage to solve your problem? if so could you please provide the steps you used, i have the very same problem:(
