I have a budget of £1100 Looking for a laptop with thin edges and looks good ( has a modern look).
Has 8 or 16 GB of RAM (8 GB is ok) the processor can be a i5 or i7 (dont have a preference here just not a celeron or i3), if possible GPU boosted graphics. The laptop has to be light as i will carry it everyday.
I would prefer USB c charging if its possible as i don't want to carry 10000 different cables to charge my phone and laptop the battery has to last me around 5 hours.
I live in the UK so any UK site that sells laptops will do to purchase the laptop.
Thank you for your help,
https://linustechtips.com/topic/1113099-need-help-with-choosing-a-laptop/
you can't get any better than this in terms of value for money :
Custom Built MSI ALPHA 15 A3DD-004 - 15.6" FHD 144Hz 3ms - 7 3750H - RX5500M
HIDevolution ships internationally and their customer service and quality control is superb
I recommend you tick the thermal paste upgrade option: Thermal Grizzly Conductonaut + Fujipoly Extreme Thermal Pads" That alone reduces temps by up to 15C to ensure the laptop doesn't overheat and thermal throttle.
ASUS ROG Strix SCAR 16 G635LX | Intel Core Ultra 9 275HX | SK Hynix 64GB DDR5-5600MHz RAM | GeForce RTX 5090 | BOE NE160QDM-NM8 16" WQXGA 240Hz Mini-LED Display + AOC Agon PRO AG274QZM QHD Mini-LED Monitor | 2x WD_BLACK SN850X 8TB SSDs (RAID 0) | Intel Wi-Fi 7 BE200 WLAN | Windows 11 Pro
