Hello, I'm really confused right now, because when i plug my GPU into PCI-E1 slot, nvidia drivers starts reinstalling itself after every reboot. But when I plug my GPU into PCI-E4 slot, everything works good, but as I know that slot is slower than the first one, so maybe I can tweak some settings in the bios, or maybe someone had a same issue?
My GPU: EVGA 1070 ti, CPU: Ryzen 5 3600, Mobo: Tomahawk max.
https://linustechtips.com/topic/1111777-issues-with-pci-e1-slot/
why would you want to put your GPU in a x1 or x4 slot?? You would be neutering the card and its performance... Needs to be in x8 at least for it to perform properly.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
he means slot PCI_E1 (It's a 16x slot, just is called PCIE-1 because it's first), at least I assume that's what he is talking about.image.png.1cdb17f1b188be90d928f31cf2e6fc92.png
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
as for your issue, try DDUing the drivers, rebooting without any gpu driver and installing it again. Otherwise there really isn't much of a performance loss at all on a 1070Ti @ 4x3.0
why no dark mode?
Current:
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
I already did it - same. And the other slot is 4x 2.0 that's why I'm concerned.
