I need help configuring the group policy, always automatically restart at the scheduled time. I set the policy to enabled and I did net get a restart timer, and after 15 minutes pc did not restart nothing happened! I also want to check, download, and install updates automatically but, for some reason it is also not working. I want to do this so that way my PC will always be up to date even when I am not at my PC.
Any help would be greatly appreciated thanks! @LinusTech or any LMG staff can you please help if you have knowledge on the topic?
Edited by Thomas001
  • My system specs
  • View 91 Tempered Glass RGB Edition, No PSU, XL-ATX, Black, Full Tower Case
  • ROG MAXIMUS XI EXTREME, Intel Z390 Chipset, LGA 1151, HDMI, E-ATX Motherboard
  • Core™ i9-9900K 8-Core 3.6 - 5.0GHz Turbo, LGA 1151, 95W TDP, Processor
  • GeForce RTX™ 2080 Ti OC ROG-STRIX-RTX2080TI-O11G-GAMING, 1350 - 1665MHz, 11GB GDDR6, Graphics Card
  • ROG RYUJIN 360, 360mm Radiator, Liquid Cooling System
  • 32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
  • AX1600i Digital, 80 PLUS Titanium 1600W, Fanless Mode, Fully Modular, ATX Power Supply
  • Formula 7, 4g, 8.3 (W/m-K), Nano Diamond, Thermal Compound
  • On AIO cooler 6 x NF-F12 IPPC 3000 PWM 120x120x25mm 4Pin Fibre-glass SSO2 Heptaperf Retail
  • 6 x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM, 158.5 CFM, 41.3 dBA, Cooling Fan
  • 1TB 970 PRO 2280, 3500 / 2700 MB/s, V-NAND 2-bit MLC, PCIe 3.0 x4 NVMe, M.2 SSD
  • Windows 10 Pro 64-bit
  • Beyerdynamic MMX 300 (2nd Generation) Premium Gaming Headset
  • ROG PG279Q
  • Corsair K95 Platinum XT
  • ROG Sica
https://linustechtips.com/topic/1111352-need-help-with-group-policy-settings/
Honestly if you want your PC to "always be up to date even when I am not at my PC" then the normal Windows 10 update settings should do you fine, provided you set your active hours and such. I've had my PC set up that way and haven't had issues with updates or messing (too much) with group policy. About the only thing I turned on in group policy was no auto-restarting during active hours I think? I'm not sure.
Windows never downloads, installs, or restarts to update automatically, I always have to do it manually by clicking check for updates.
  • My system specs
  • ROG PG279Q
  • ROG Sica
