Hi everyone,
My rear case fan sometimes doesn't properly startup sometimes. Which fan should i buy to replace it? I don't wanna buy something worthless for 3$ and also don't really want to spend 25$ on a single fan. (Btw, it has to support PWM and be 120mm)
Thank you for any suggestion
https://linustechtips.com/topic/1110721-case-fan-suggestions/
Noctua's black 120mm PWM fans are only $14.99 on Amazon.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1110721-case-fan-suggestions/#findComment-12942890
What case are you using?
Where are you shopping / located? Budget?
https://linustechtips.com/topic/1110721-case-fan-suggestions/#findComment-12942916
I'm using the Aero Cool case. Unknown but has a mount for the double radiator, dust filters, side window, and just serves me really well. I'll probably buy on Amazon and looking between 8$ and 15$
https://linustechtips.com/topic/1110721-case-fan-suggestions/#findComment-12942932
What country are you shopping from?
If you're not sure what case you have, please post a photo of the rear fan mount mesh.
https://linustechtips.com/topic/1110721-case-fan-suggestions/#findComment-12942941
1 hour ago, Memphills2 said:
The case is Aerocool 1000. I'm from the US
The rear mesh is fairly open so a NF-S12B would work wellhttps://pcpartpicker.com/product/bKFPxr/noctua-case-fan-nfs12bredux1200pwm
https://linustechtips.com/topic/1110721-case-fan-suggestions/#findComment-12943966
20 hours ago, Firewrath9 said:
wait can I get a link? Do you meant the redux fans?
It might have been, I can't find the ones I saw the other day.
https://linustechtips.com/topic/1110721-case-fan-suggestions/#findComment-12944843
Redux fans are gray. If you're referring to black fans, they're probably Chromax fans but they're usually 20-25 USD.
https://linustechtips.com/topic/1110721-case-fan-suggestions/#findComment-12945537
