What Monitor should I get? HELP
Sparky_Fr
Hi all,
I'm planning on buying a new monitor soon.. but am struggling to decide what one to get!
My criteria is :
Good color reproduction
At least 144Hz
27" and under 500£
I've found the LG and ACER... I like the LG thanks to it's amazing reviews and DCI-p3 range..
I also like the ACER due to it's 165Hz refresh rate...
Please share your opinions.. Maybe propose another monitor that I've not found!
Thanks,
(my PC specs are in the signature)
MAIN RIG = CPURyzen 5 3600 @4.2 on all cores Mobo: MSI GAMING PRO CARBON AC RAM:Corsair Vengeance LED 16GB 3400MHz DDR4 GPU:MSI GTX 1080 GAMING X OC Storage: Corsair MP510 NVMe M.2 480GB, 2x SSD HyperX Fury 512GB (games) PSU:EVGA Supernova 850w G+ Gold Display(s): , LG GL850 1440p 144Hz, HP Z24i (Color Accurate work) Cooling: Hyper 212 LED with Noctua NF-P12 Keyboard: Corsair K68  Mouse: Logitech G502 HERO Headset: AudioTechnica ATH M50x  Case Thermaltake Versa H27
Laptops =  HP Elitebook z17 G5 (i7 8850H, Quadro P5200, 64Gb DDR4)
Alienware 17 R3 ( i7 6700HQ, GTX 965m, 32Gb DDR4)
I would go with the LG because of the much newer panel technology, afaik the Acer is pretty old at this point.
Also you won't see the difference between 144 and 165hz, it is a much smaller difference than between 60 and 75hz displays.
I only see your reply if you @ me.
This reply/comment was generated by AI.
The contrast ratio of the LG is worse than than others but other than that it's fine.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
