212 evo fan
Go to solution Solved by Tmh85,
Sp120s will do fine
Hi guys,
The fan on my cm 212 evo is not sounding very healthy anymore so i wish to replace it before it decides to fail and would like to know what you think would be a good replacement for it. I have heard good things about noctua however i dont really like the asthetics of them. Preferably im after somthing like the original and was considering a corsair sp120 what to you guys think is there anything better?(will be purchasing from amazon as i have a few other things to get anyway)
https://linustechtips.com/topic/111008-212-evo-fan/
Sp120s will do fine
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/111008-212-evo-fan/#findComment-1483425
Get Schythe Gentle typhoons. They are as good as noctuas but black.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/111008-212-evo-fan/#findComment-1483435
Do you care about noise? Budget?
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/111008-212-evo-fan/#findComment-1483436
budget is not really an issue unless its crazy amounts, as for noise should be about the same as the original or better at 36 dBA.
SP 120s are good fans. Scythe Gentle Typhoons like @Swegly said are basically the best fans on the market however they are not that easy to find anymore.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/111008-212-evo-fan/#findComment-1483481
the corsair sp120 high performance is i think 35db
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/111008-212-evo-fan/#findComment-1483495
Eloops if you can (push only), also cougar vortexes are good if you don't mind the ugly colors
he doesnt like noctua cuz of the colors.
Edited by Rheinwasser
https://linustechtips.com/topic/111008-212-evo-fan/#findComment-1483595
thanks for the double quote
also I never recommended noctua's, it's just in my opinion i don't like the look of the vortex
edited, im on a phone, sorry. he does mind ugly colors, so its pretty likely that he doesnt like the vortex.
https://linustechtips.com/topic/111008-212-evo-fan/#findComment-1484351
