This is strange, I've just built my dads new computer.
Checked that everything works installed some programs and windows update.
I installed hwmonitor to check the CPU temperature (amd athlon x4 760k, cooled with a artic cooling freezer 7 pro)
And it says the cpu temperature is hovering around 70idle and it shoots up to 120c when ever I do anything...... what why is it so high?
I've re-seated the cooler and no change...
Coretemp wont even show the temperature of the cores, just a 0's
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/111000-cpu-temperature-issues/
Make sure the CPU is properly recognized in the BIOS and is running at the proper clock speed and voltage.
You say you re-seated the cooler, so can we assume you properly used thermal paste on the cooler? And you didn't do something doofus-ish and leave a plastic cover on the bottom of the cooler?
Edit - a good point above - are those temps in F rather than C?
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/111000-cpu-temperature-issues/#findComment-1483366
Nah I'm not that silly.
Yes I used enough paste on the bottom, I'm using my old cpu cooler, so I know how well it supposes to do and theres nothing on the bottom.
Temps are in C.
Is fluctuating all over the place from 70 to 120 in a split second...
Even the voltage is jumping around from 0.896 to 1.3...for no reason in CPU-Z, I've not even touched anything in the bios...
Here is when I open a program (not doing anything, just opening it)
http://i57.tinypic.com/zogxuu.png
The computer is showing no sign of being overly hot inside, but no other program will show me the cpu temperature.
The BIOS shows the temperature as around 70 however, which is always higher than it is while actually booted up...
I dunno what to do
EDIT:
Checked speedfan - according to that the CPU temperature is sitting around 40idle and when I do what I did above only goes to around 55-60c....
so i dunno which to believe...
https://linustechtips.com/topic/111000-cpu-temperature-issues/#findComment-1483383
There is no way you can monitor a CPU at 120C it will just turn balck and turn off (the monitor), no blue screen or anything. Also what is your thermal thresehold in the BIOS? Did you use too much thermal paste? that can cause a lot of problems. Did you perfectly clean both surfaces before reseating? you should be using rubbing alcohol.
https://linustechtips.com/topic/111000-cpu-temperature-issues/#findComment-1487464
To ensure you're getting the right reading, check the CPU temp. in the BIOS.
"Rampage IV" - Gaming PC
Cooler Master HAF 932 Advanced    EVGA GeForce GTX 980                            ASUS VE278H 27in LED Monitor x 3
ASUS Rampage IV Black Edition         G.Skill Trident X 16GB DDR3 2400Mhz     Cooler Master Silent Pro Gold - 1000W
i7 4930k - Overclocked @ 4.5GHz     Samsung 850 SSD 250GB x2 RAID 0           Western Digital Blue 1TB
Logitech G930 Wireless Headset      Razer Naga 2012 MMO Gaming Mouse      Logitech G710+ Mechanical Keyboard
"EMCMS-ESXI" - Server
HPZ800 Workstation Chassis           Seagate 4TB NAS Drive x 4 RAID Z           48GB ECC Elpida DDR3 SDRAM
Xeon E5620 @ 2.66GHz x 2             PNY CS2211 240GB SSD                          HP 80 PLUS Silver APFC PSU - 1110W
LSI 9211-8i SAS in IT Mode
https://linustechtips.com/topic/111000-cpu-temperature-issues/#findComment-1490168
it looks like a sensor or software bug where the temp is virtual going to the max only. i would only be worried if the temp stayed at 120 oc.  it not possible for the temp to go from 50 to 120 in 1s and back again.
https://linustechtips.com/topic/111000-cpu-temperature-issues/#findComment-1496332
