Cable extension for Seasonic Focus Plus 750 Gold
Solved by TempestCatto,
3 minutes ago, Zator said:I need to check, but is it really worth to buy cables instead of extensions?
With extensions you increase the amount of failure points. Personally, I'd just build the PC now and add more aesthetically pleasing cables later.
Tannim ·
Posted in Servers, NAS, and Home Lab4 -
niznez ·
Posted in Graphics Cards2 -
11
1
15
1
play_circle_filled
Latest From Linus Tech Tips:
Even I’M Jealous of These Guys - Reacting to r/HomeLab
