Which one is good as a decent overall phone? I understand about the US ban and the 30 not having google apps, but i use Microsoft Edge and Cortana. I could live without the YouTube app and I have a chromebook from school to use google services. Also, is it possible to use google docs and stuff on web browser?
https://linustechtips.com/topic/1105818-huawei-mate-10-pro-20-pro-or-30-pro/
17 hours ago, -Kriss- said:
All of them should be fine. The 30 pro isnt out yet but unless there is an actual block from google (even then someone will probably find a way around it). Rooting and downloading gapps isnt difficult if you have to have them.
Whats the best way to get Google apps safely without viruses and such?
Be warned! Huawei is being an a** like all the other mainstream manufacturers now and NOT ALLOWING Bootloader unlocks on their devices (at least on the international version)! There are some sketchy Russian services to unlock them though, Root is very difficult with a locked bootloader and TWRP is near-impossible unless someone develops a safestrap-like recovery. It can be done but it's a long drawn our process.
why no dark mode?
Current:
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz, Asus VG248QE 1080p@144hz
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 512GB HP EX NVMe SSD, 2TB Silicon Power NVMe SSD
Displays: Internal 1080p@300Hz
Custom Game Server:
CPUs: Ryzen 9 9900X
RAM: 128GB (4x32GB) DDR5 @ whatever it'll boot at xD (I think it's 3600MTs)
Storage: 2x 1TB WD Blue NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
