HI! I cannot seem to get my GPU to output any signal to my monitor, it is a RX 580 Red dragon, I put it in a system with a proprietary Power supply, so i used a old Bestec power supply to deliver power to the card, and connected two cables on the 24 pin (Green and black), The fans spin up, and it shows up in device manager as a RX 580 series Card,I've tried uninstalling and re installing drivers, but nothing seems to work, is there something ive missed? the system is a HP 590 p-00020 w/ryzen 3 2200g
https://linustechtips.com/topic/1105262-dual-psu-problem/
Did you connect a display to the card? The Radeon cards require a display to be attached in order for the system to register the GPU for the driver to be installed.
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12898905
hope you have your phone close to you with the fire department on quick dial..
CPU & COOLER - INTEL i9 12900K | NZXT KRAKEN X62
MBO - MSI Z690 EDGE
GPU - ASUS GEFORCE RTX 3080 TUF
RAM - 2x16GB KINGSTON FURY 3200MHZ
PSU - PHANTEKS REVOLT PRO 1000W 80 PLUS GOLD
SSD #1 - CORSAIR SN850 1TB
SSD #2 - CORSAIR SN850X 4TB
SSD #3 - INTEL 660p 2TB
CASE - PHANTEKS ECLIPSE P500A D-RGB
MOUSE #1 - LOGITECH G502 X Wireless
KEYBOARD - AKKO 5108B PLUS
SPEAKERS - SVS PB-1000 + 2x ADAM A3X
HEADSET #1 - SENNHEISER IE-300
HEADSET #2 - FOSTEX TR-X00 PURPLEHREART
AMP/DAC - MAYFLOWER ARC
OS - WINDOWS 10 PRO
DISPLAY 1 - LG OLED42C2
DISPLAY 2 - XIAOMI 2K GAMING
PHONE - SAMSUNG GALAXY S23+
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12898988
So you are trying to upgrade a prebuilt...
How many Watts is the PSU?
It is made in Taiwan so there is a chance it's OK...
Just need the exact model number and check reviews -_-
I have done a dual PSU once for troubleshooting a 600w crossfire setup (that's the power consumption)
And what display cable do you use?
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12899060
Running two PSUs is hardly dangerous if done properly, there is a chance for failure but unlikely.
I would recommend an add2psu for easier operation:
https://www.amazon.com/Multiple-Adapter-Connector-Genetek-Electric/dp/B0711WX9MC
Have you confirmed that this GPU runs in another system?
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12899069
47 minutes ago, Razer06 said:
I have, but nothing shows up on the display
Check your BIOS settings. There may be display options that state weather it's using iGPU/dGPU or both. If it's set to use strictly the iGPU then the dGPU will not output anything and may have other issues like this.
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12899133
I did, there were some settings about the pcie rail, i enabled them and the card ran, found out the PSU was the problem
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12900692
No. I bought it at Micro Center and they said they tested it and it worked, so I trusted them, found out the power supply was absolute crap, im probably just gonna buy a 80+ Bronze one from rosewill or EVGA
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12900698
The PSU is 250 watts, it is a Bestec ATX-250-12z. I use a AmazonBasics HDMI to VGA Cable. Im going to try another PSU that i have tonight, Itś another Bestec, This time 300w.
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12900712
Those power supplies are really really bad,the worst of the worst,and the worst i have ever seen in those forums...
AVOID THEM FIRE HAZARD,EXPLOSION HAZARD,TOXIC GASES HAZARD.
And the HDMI to VGA is another potential point of failure.
No wonder it doesn't work,
I would recommend just buying a good PSU.Yes it will cost more money but at least it will actually work and be reliable.
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12902255
Thats why im gonna buy a Corsair or thermal take PSU off amazon, this only has to last 1 day without breaking, I know they are absolute garabge.
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12903178
Also I got my system to work, it wasnt the psu, also i left it under load for a bit, it never went super hot, and i could play forza, fortnite, Project Cars, etc, on max settings,
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12903234
What was it?,The display cable?...
https://linustechtips.com/topic/1105262-dual-psu-problem/#findComment-12903755
