MSI RTX 20270 Armor 8GB - Do I need to plug in both 6 and 8 pin power?
Go to solution Solved by Guest,
3 minutes ago, t33to said:
So this power lead coming from the PSU has a 6pin+2 on it, and another 6pin+2 at the end of it. That is OK?
Its a 750w corsair.
Yep. You can post a picture of it just to confirm if you'd like.
The graphics card has ports for a 6 pin and an 8 pin.
1. Do I need to have both a 6 pin AND an 8 pin plugged in? Or can it be either or?
2. If it needs to be both, can I use a power lead from the PSU that has a 6pin AND 8pin on the same lead?
Thanks!
Its a 750w corsair.
