Best gpu for 1080p 60hz monitor?
Go to solution Solved by GoldenLag,
17 minutes ago, Sophia Loren said:
Many people said that there will be screen tearing and lagging something like that.
thats just lies....... tearing occurs when 2 different frames are drawn on screen at the same time.
it might be a tad powerful for 1080p, but its gonna do 1080p for a pretty long time.
So it wouldn't be a good experience playing on it.
it would be a mighty fine experience playing on it. you might want to enable Vsync if some tearing occurs (thats not linked to the GPU being too powerful).
you can use the 2060 no problem.
Hi guys,
I'm stuck on deciding the gpu of my pc build. Just when i finally decided to buy the RTX 2060, i just found out that it is overkill for my full hd 60hz monitor. Many people said that there will be screen tearing and lagging something like that. So it wouldn't be a good experience playing on it. I just bought the monitor last month and it wasn't my plan to build a pc at that time. My plan was to buy a gaming laptop. But i have changed my mind and thought to build a gaming pc instead. Now I'm not sure which gpu to buy. I can't upgrade my monitor for at least 2 or 3 years so I'm not sure which gpu would be compatible with my 60hz monitor. My monitor does have free sync in it. So i am thinking maybe 1660 ti would be compatible. Please any help would be much appreciated. Thanks!
https://linustechtips.com/topic/1101885-best-gpu-for-1080p-60hz-monitor/
Just now, Sophia Loren said:
What's your budget/country for the PC?
PC SPECS:
- cpu: AMD Ryzen 5 3600
- mainboard: MSI B450 TOMAHAWK MAX AMD Motherboard
- graphic card: GALAX RTX 2060EX (1 Click OC) 6GB GDDR6 Graphics Card
- psu: Antee NeoEco 650M 650 Watt 80 PLUS Bronze Semi Modular Power Supply or CORSAIR CX650 650 WATT 80 PLUS BRONZE CERTIFIED MODULAR ATX POWER SUPPLY
Thanks!
That's great to hear. I am trying to build my first pc.
PC SPECS:
- graphic card: GALAX RTX 2060EX (1 Click OC) 6GB GDDR6 Graphics Card { This the highest gpu i could get under my budget for gpu}
Thanks!
get this one, not the other one.
you might be able to get a aftermarket rx 5700, but pricing can be "eh" on those. so that there does seem like the best you can get.
okay. thank you for your recommendations.
Get the 2060 and run your stuff on ultra. Sure it’s overkill right now but it should age well on a 60hz monitor
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Xfx 7900gre
Fractal Ion 2+ 860watt platinum
Be quiet 500dx
Samsung G8 Oled Ultrawide
Aoc Q27G3XMN mini led
Xbox series x
