I'm planning parts for my first build. I have put together a list of parts for the build, I have used pcpartpicker to check If my parts are compatible. I have done some research and would like someone who is more experienced to go over my build to see if my parts are compatible. Any help would be appreciated, please and thank you.
Here is a link to the list of parts: https://t.co/eKBVFPITa7?amp=1
https://linustechtips.com/topic/1101692-need-experienced-pc-builders-please-help/
5 minutes ago, ItzTheRealDINO said:
pcpartpicker
If PCPP says the parts work together, then you can be certain they do (at least, I've never seen an issue where PCPP was wrong)
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
I would buy two 4TB drives instead of one 10TB (cheaper and safer - or you can use raid for speed them up). But that requires pc case that is not only good looking but also functional (more space for storage, less space for crappy fireworks). Also - I prefere BeQuiet Straight Power but Corsair is good too.
I'm not saying "better buy xxxx" (where "xxxx" is Ryzen or different card etc). If it's your choice - it's your choice (personally I don't trust Asus GPU after having two of them - and both have problems with fans sooner or later).
that should all work together
Builds:
2 hours ago, ItzTheRealDINO said:
Gaming and streaming
You could get a 3900X build for the money you are spending. I assume around $2400 looking at your Amazon parts list ?
If you need to knock some money off then a 3700X would do fine.
PCPartPicker Part List
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($499.99 @ Best Buy)
CPU Cooler: Cooler Master MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($139.89 @ OutletPC)
Motherboard: Gigabyte X570 AORUS PRO WIFI ATX AM4 Motherboard  ($269.79 @ SuperBiiz)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($99.99 @ Newegg)
Storage: Sabrent Rocket 2 TB M.2-2280 NVME Solid State Drive  ($249.98 @ Amazon)
Storage: Toshiba X300 4 TB 3.5" 7200RPM Internal Hard Drive  ($99.99 @ Newegg)
Video Card: Gigabyte GeForce RTX 2080 SUPER 8 GB WINDFORCE OC Video Card  ($719.99 @ Newegg)
Case: Cooler Master MasterCase H500 ATX Mid Tower Case  ($144.98 @ SuperBiiz)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.89 @ OutletPC)
Total: $2434.48
Generated by PCPartPicker 2019-09-05 17:55 EDT-0400
43 minutes ago, ItzTheRealDINO said:
The one I have planned out is cheaper
But we have no idea of the total cost of your build.
It will all work.
However, for an i9-9900K I'd suggest a higher capacity psu, 750W would be my recommendation.
The 1TB NVMe Crucial P1 is available at a lower cost than the Barracuda ssd. It also has better performance.
I have my doubts about the case and would suggest a Corsair case that comes with 3 RGB (as opposed to fixed color) fans. With that change, I'd also suggest changing the cpu cooler to one with two RGB fans. These changes will result in a system with RGB lighting that you should be able to sync using the motherboard's Aura Sync or Corsair iCUE software.
CPU: Intel Core i9-9900K 3.6 GHz 8-Core Processor  ($494.99 @ Amazon)
CPU Cooler: Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler  ($159.99 @ Amazon)
Motherboard: Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard  ($226.50 @ Amazon)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory  ($99.99 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Video Card: Asus GeForce RTX 2080 SUPER 8 GB STRIX GAMING Advanced Video Card  ($789.99 @ Amazon)
Case: Corsair iCUE 220T RGB Airflow ATX Mid Tower Case  ($109.99 @ Amazon)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.89 @ Amazon)
Total: $2106.33
Generated by PCPartPicker 2019-09-05 20:11 EDT-0400
