MSI Gaming Pro Carbon 8+4 CPU power?
Solved by GoldenLag,
the extra 4 pin is useless and doesnt do anything other than looking impressive on a board.
the same is said about an extra 8 pin.
this is because a minimum spec 8 pin EPS connector can deliver 384 watts to the CPU. which you wont exceed with a consumer CPU without resorting to liquid nitrogen. also the VRM is likely to blow up before the 384 watt is reached.
edit: also good luck cooling 384 watts
