stock cooler
I don't plan on overclocking, I just want something to replace the stock cooler that works.
for under 15$ the answer would still be stock cooler.
this worth buying is a serious stretch, but it's your call.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103074
Error: 410
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1470540
Nah, use your lungs and save up for a hyper evo
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1470542
The stock cooler. Stretch your budget like $15 more and get a Hyper 212 EVO
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1470543
stock cooler
This product is shit, better to use the stock cooler.
ASUS ROG G75VX
Intel i7-3630QM 2.4GHz/3.4GHz Turbo | Nvidia GeForce 670MX 3GB OCed to 736MHz | 750GB HDD | Windows 8.1 | 24 GB 1600MHz RAM | Razer Goliathus Medium | Logitech G400s | Razer Kraken/ JBL J22 | Corsair Vengeance K70 Cherry MX blue
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1471030
If you don't plan on overclocking, I think that the stock cooler is sufficient. You see many people buying coolers because majority of people who build computers would overclock but stock cooler in my opinion is good enough. The CM 212X is a good upgrade if you want a more quiet system.
ASUS ROG G75VX
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1471050
it is, but there's nothing else to buy
it's the golden turd among charcoal
If there is nothing else to buy then don't buy. That is the solution.
ASUS ROG G75VX
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1471060
There's nothing wrong with the stock cooler if you're not looking into overclocking. If you want a better cooler at least get a Hyper 212 Evo.
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1471079
you realize I'm telling him not to buy it, right? But I'm giving him the best of the worst options if he chooses to ignore what I say.
He can do what he wants, I'm not going just say flat out no.
Error: 410
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1471080
The absolute cheapest CPU cooler I'd buy is the Raijintek Aidos. In UK it's £14.99 but that would be around $23 though I don't think it has made it to the US market yet.
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1471400
Arctic Cooling Alpine 11 GT/Pro.  They're dirt cheap, about as good as stock or maybe a little better, and SUPER quiet compared to stock.  When building non OC computers, I spend the extra couple bucks and get one of these, because quiet!
http://products.ncix.com/detail/arctic-cooling-alpine-11-pro-rev-2-cpu-heatsink-cooler-lga1155-lga1156-lga775-with-92mm-pwm-fan-5f-42382-1010.htm
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1472589
Without overclocks, the stock cooler is really sufficient, and then save up to buy a low profile noctua cooler for more silence.
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
https://linustechtips.com/topic/110070-15-cpu-cooler/#findComment-1473240
