Python if input is "ls" then print
Go to solution Solved by Guest,
@ughiwanthackintosh Do you mean something like this? Or something else?
Code 1:
while True:
  user_input = str(input("Enter a word: ")) #input from user
  if user_input == "ls": #checks if input is similar to assigned command
    print("Works") #prints message then exits loop
    break
  elif user_input == "as": #checks if input is similar to assigned command
    break
  elif user_input == "bn": #checks if input is similar to assigned command
    break
  else: #if input is not similar
    print("Error: invalid syntax") #prints message then returns to start of loop
  continue
If so, you can replace "break" with "continue" if you wanted the user to stay in the loop, but you'll need to add another if statement for them to exit the loop.
Edit: this loop works somewhat similarly to what you provided earlier, with additional commands and an if statement for exiting the loop.
Code 2:
while True:
  if user_input == "ls": #checks if input is equal to "ls"
    print("Works")
    continue #returns to start of loop
  elif user_input == "as": #checks if input is equal to "as"
    print("Works")
  elif user_input == "bn": #checks if input is equal to "bn"
    print("Works")
  elif user_input == "exit": #checks if input is equal to "exit"
    print("Exiting")
    break #exits loop
  else: #if input is not available
Difference between code 1 and code 2: code 1 exits the loop if the input is correct/available, while code 2 stays in the loop if the input is correct/available.
1 minute ago, lewdicrous said:
at code means: while i is less than 6, print i, then add 1 to i.
i += 1 means i = i + 1.
.. still dont understand a thing
ave you done any basics? that a good place to start before you start making your own projects.
This might help a bit.
nope havent i just jumped onto hello world and calc and im here now
will watch!
i = 1 # i can be any number in this example
while i < 6: # check if i is less than 6
  print(i) # print i
  i += 1 # add 1 to i then check again
  # when i is equal to 6, the loop stops
# here's another example
y = 10 # in this case, y is equal to 10
while y > 0: # check if y is greater than 0
  print(y) # print y
  y -= 1 # subtract 1 from y then check again
  #when y is squal to 0, the loop stops
Is this a better explanation?
12 minutes ago, lewdicrous said:
That code means: while i is less than 6, print i, then add 1 to i.
You gotta find a way to incorporate that while loop into the code you want to make, but not necessarily the way the code you linked shows.
Have you done any basics? that a good place to start before you start making your own projects.
i posted this secounds after you posted above me
before you leave me in the infinite hell of guides and years of trubleshooting can you provide a working while loop?
i understand this:
while (expr) # waiting for break
break  # pauses
continue # continues from break
but how do i make it go back up to
37 minutes ago, lewdicrous said:
# input a string
x = str(input("Enter a word: "))
# if input is correct, print
if x == "ls":
  print("Works")
elif x == "as":
  print("Works")
elif x == "bn":
  print("Works")
# if input is wrong, print
else:
  print("error: invalid syntax")
Something like this maybe.
An if statement for every input you want, although the code could get long.
The code I tried didn't work.. trying to debug it now lol
I haven't been coding for over a year, so I'm a bit rusty.
I've also only taken one course on it, so I'm by no means an expert.
  print(i) # print i
  print(y) # print y
i understand what your doing in that code atleast somewhat
but i dont get where to put the other code
your better than me obv thanks for helping :D
dont need to be an expert :D
i thank for any help :D
That's just an example of a while loop, you'll need to change it if you want your code to work the way you want.
Those examples are just counters, if you will.
This is the output of the first example:
This is the output of the second example:
You can use this site https://repl.it/languages/python3 to test codes quickly.
im using Pycharm for windows, but if i need an alternative ill use repl it
pycharm
the problem is idk how i should change it to make it work my my current code...
im not that good yet, but you can try to explain if you want
pycharm
Repl is an online compiler, IDE and not something you have to download.
You can still use pycharm, but if you want to test a simple code like the ones I explained, then you can use Repl for those.
mhm!
however where do i place the while loop in the code?
also you never posted your debug'ed code
I think what you're looking to do is use conditions and loops, but I'm not sure about how to incorporate it in the way you want.
isnt there like a thing like this???
:1
code code
code code
code code
goto :1
like in batch scripts, there was exactly that. like
:choice
set /P c=Are you sure you want to continue[Y/N]?
if /I "%c%" EQU "Y" goto :y
if /I "%c%" EQU "N" goto :n
goto :choice
:y
echo "y"
pause
exit
:n
9 minutes ago, lewdicrous said:
We write - snip - to shorten the quote.
oh! so id get the a notification! brilliant
class label(Exception): pass
try:
    if condition: raise label()
except label:
    pass
this code does not work, i tested it
i did change the label to goto top
pic listed below does not work much better
That code was just an example, it will not work out of the box; you gotta make it work for what you want.
Search for "python goto substitute"
do you know how i can make the code work ? beacuse googling "python goto substitute"
opens an infinite hell of trubleshooting
I think this is what you're trying to do, but I'm not sure about how to get it to work.
it is i think.
should i ask other forums?
on the topic? or? maybe someone there knows how? :)
it is i think.
Up to you, you might find an answer in stack overflow or some subreddit, but you might also find the answer on YouTube.
Best of luck to you.
thanks. ? im gona ask the python discord server
@ughiwanthackintosh Try this out.
while True:
  user_input = str(input("Enter a word: ")) # the word/letters the user has to input
  known_commands = ("ls", "as", "bn") # list of words/letters to make the code shorter and more compact
  if user_input in known_commands: # checks if user_input matches something in known_commands
    print("Works") # if so, prints
    break # exits the loop
  else:
    print("Error: invalid syntax") # if not, prints
  continue # returns to the start of the loop
