Python if input is "ls" then print
Go to solution Solved by Guest,
@ughiwanthackintosh Do you mean something like this? Or something else?
Code 1:
while True:
  user_input = str(input("Enter a word: ")) #input from user
  if user_input == "ls": #checks if input is similar to assigned command
    print("Works") #prints message then exits loop
    break
  elif user_input == "as": #checks if input is similar to assigned command
    break
  elif user_input == "bn": #checks if input is similar to assigned command
    break
  else: #if input is not similar
    print("Error: invalid syntax") #prints message then returns to start of loop
  continue
If so, you can replace "break" with "continue" if you wanted the user to stay in the loop, but you'll need to add another if statement for them to exit the loop.
Edit: this loop works somewhat similarly to what you provided earlier, with additional commands and an if statement for exiting the loop.
Code 2:
while True:
  if user_input == "ls": #checks if input is equal to "ls"
    print("Works")
    continue #returns to start of loop
  elif user_input == "as": #checks if input is equal to "as"
    print("Works")
  elif user_input == "bn": #checks if input is equal to "bn"
    print("Works")
  elif user_input == "exit": #checks if input is equal to "exit"
    print("Exiting")
    break #exits loop
  else: #if input is not available
Difference between code 1 and code 2: code 1 exits the loop if the input is correct/available, while code 2 stays in the loop if the input is correct/available.
Use input as per the documentation.
I would show you the full code but this smells like homework and it only takes a few minutes to find and read the relevant docs or look up a basic tutorial.
sudo chmod -R 000 /*
homework? its sunday... in norway there is no friday homework so no, but please link me to those spicy docs
Ive googled for an hour, but nothing seems to work
Just now, lewdicrous said:
What is 'ls' meant to be?
If 'ls' is a certain word, then it's relatively easy to solve, but I won't solve the homework for you (if it is homework)
it isnt homework..
if you write ls into the input then, run an certain thing,
im trying to build a thing like a command line
So where are you at with the code now? Seems like at least getting input should be easy, comparing strings is quite a simple thing too.. And else is just.. else.
A big part of programming, is debugging. So start introducing breaks in your code (or simple print statements) to see the value of your variables and to see where your code is actually going (e.g. 'is it going into the if or else' type stuff).
also your input link isnt working ngnix
3 minutes ago, ughiwanthackintosh said:
it isnt homework..
What have you tried to do so far?
I got it to work in 5 lines.
Something like this?
if ls was typed. then run a command if ls wasnt typed, wait for another command or ls
im trying to make a "command line" like script
ive tried and gotten this code to work,
start_over = 1
question = input("Do you wish to try again? y/n: ")
if question == "y":
    start_over -= 1
else:
    raise SystemExit
also im alot of a starter so sorry if i am being stupid
yes something like that but with multiple inputs, like
if ls then print something if input is clear then print something else and then if input is version then print something else again and on and on
Right, sorry about that, it's fixed now. You could also find it by googling "python input".
If it's not homework you could try something like this
if input() == "ls":
  print("works")
else:
  print("doesn't work")
as for where the docs are, there's literally a link to them on the python homepage and I strongly doubt you "googled for an hour" and couldn't find them, it's the first result for "python documentation".
Yea I understood that, but what code do you have that is not working now?
Like where are you at right now after that hour of Googling? Can you receive user input?
Is Python the same as Pycharm?
start_over = 1
if question == "y":
    start_over -= 1
else:
    raise SystemExit
From what I read here:
https://www.pythonforbeginners.com/basics/getting-user-input-from-the-keyboard
It looks like 'input' reads integers (numbers with no decimal points), so try using 'raw_input' there.
EDIT: nvm, that's wrong it seems..
Also, I am fairly sure you need to use a single apostrophe when comparing two strings. So that means a single apostrophe around the 'y'.
It might be better at this point to also include a simple 'print' statement on the if and else to see how far your code gets.
if input() == "ls":
  print("works")
else:
i didnt google for the docs. but i googled "python if input is then" and "if python" and simmilar things
16 minutes ago, ughiwanthackintosh said:
... well idk how you did that but please learn me
# input a string
x = str(input("Enter a word: "))
# if input is correct, print
if x == "ls":
  print("Works")
elif x == "as":
  print("Works")
elif x == "bn":
  print("Works")
# if input is wrong, print
else:
  print("error: invalid syntax")
Something like this maybe.
An if statement for every input you want, although the code could get long.
i am at this point after googling:
print ("Version 3.2.")
print ("Type Help for list of commands.")
input1 = input (">")
result = print (" ")
input2 = input ("")
input3 = input (">")
thats when i goto the part of multiple inputs and if input isnt clear then either invalid syntax, or if its ls then run some else code
yes pycharm is a ide editor and executor of python
could try that yes
11 minutes ago, lewdicrous said:
# input a string/command
if x == "ls":
  print("Works")
elif x == "as":
  print("Works")
elif x == "bn":
  print("Works")
else:
its almost perfect! but when the input is done running then loop and go back to start to run more commands
also where did you find a guide for this? in the docs? or ?
also a sidenote question,
the py script works in pycharm (google it)
but not  if i drag it into python interpreter do i need to execute a certaint command to run a py in the interpreter?
4 minutes ago, lewdicrous said:
If that's the case, then you might need to put the if statements in a while loop.
i googled it for 3 minutes now i found this:
i = 1
while i < 6:
  print(i)
  i += 1
unfortunatly im not wise enought to know how to use it or where to put it or if its even the right while loop
1 minute ago, lewdicrous said:
Just beware of infinite loops.
i = 1
while i < 6:
  print(i)
  i += 1
ill google some more while waiting for a reply in the one above
thanks for sticking around with me
i am really bad a python but i gotta start somewhere right??
found this
while <expr>:
    <statement(s)>
same problem as before i cant understand where to put it
i = 1
while i < 6:
  print(i)
  i += 1
That code means: while i is less than 6, print i, then add 1 to i.
i += 1 means i = i + 1.
You gotta find a way to incorporate that while loop into the code you want to make, but not necessarily the way the code you linked shows.
Have you done any basics? that a good place to start before you start making your own projects.
This might help a bit.
