What is the max upgrade for a intel core duo e5200 2.5ghz? I want atleast 3.3ghz but more would be best. I am a broke teen so i dont have alot to spend on new cpus
Thanks!!!!
P.S. this is the highest i found but i wanted to ask if anyone knows of any higher speed cpus that will work with my "Msi p43 Neo3"
https://www.amazon.com/dp/B001BS1ONW/ref=cm_sw_r_cp_apa_i_DjkADbV4475G8
https://linustechtips.com/topic/1099442-intel-core-duo-e5200-max-upgrade/
How much do you have to spend?
You should be able to go up to a intel core 2 quad Q9650 cpu on that board as long as the bios is up to date.
Here is a Q9550 used for around $30 shipped cpu only and is 2.83ghz https://www.amazon.com/gp/offer-listing/B00OVALJ0U
The Q9650 is a bit too expensive around $50 shipped cpu only and is 3ghz https://www.amazon.com/gp/offer-listing/B001D86S3G
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
I found the e5200 and its $10ish and 3.3ghz will that work?
Get the Q9550, dont buy a dual core cpu
14700k
2tb seagate hdd
Pny 5070ti
Ps5 Pro
Series X
I pulled up specs for the mobo they mentioned and it says with up to date bios the Q9550 will work
14700k
2tb seagate hdd
Pny 5070ti
Ps5 Pro
Series X
It’s a dual core vs quad core. Don’t buy the dual core
14700k
2tb seagate hdd
Pny 5070ti
Ps5 Pro
Series X
1 minute ago, Heavenly FLARE said:
I want to play just cause 3 so it need at least 3.2ghz
It also needs at least 4 cores, JC3 on a dual core would be an absolute nightmare. You're much better off with a quad core at a bit slower speed than a dual core.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
Don’t listen to me then and get the dual core. Make sure you post back what your frame rate is after you get it. I’d love to know
14700k
2tb seagate hdd
Pny 5070ti
Ps5 Pro
Series X
What cpu then? I also want to play the sevtech ages modpack on minecraft
Higher end Core 2 Quads are the best in socket for your platform. You're probably better off saving up and jumping platforms, even a basic i5 2400 or similar should be a massive improvement over an Core 2 series CPU, they're pretty ancient and JC3 is hard on CPUs IIRC, as is modded Minecraft, though it's usually easier to run.
Mouse: EVGA X17
I am 15 and cant get a job...im trying to find a cpu that is compatible with my mobo but can play my games....its a lga 775 so.....as long as its cheap and will work with my mobo i would rather a quad core
There's the Q9550 the other guy mentioned, lemme see if there's anything higher that's still cheap (top end CPUs for any overclocking platform usually hold value better than you'd expect them to given the age).
Mouse: EVGA X17
Ok thanks
10 minutes ago, Heavenly FLARE said:
Ok thanks
Apparently it supports Extreme Edition CPUs too, meaning you could get a QX9770 or QX9775, both 3.2Ghz quad cores. People want a cool $150-300 for those though so.... yeah. Around 2.8GHz on a quad core looks like the best you can get for any reasonable price. Maybe a 3Ghz Q9650, those are around $30 though which is eh for how little performance they offer (on X58 that gets you a 6c/12t 3.06Ghz X5675 with a turbo up to 3.46Ghz).
Mouse: EVGA X17
Is there no way to get it used for cheaper?
Those are the used ones, like I said earlier the best-in-socket OCable chips usually stay really expensive.
Mouse: EVGA X17
Will this work?.....i just want something that can run the sevtech ages modpack for minecraft and just cause 3??? i feel like it would be Easier and cheaper to build a whole new computer then buy a $300 CPU
https://www.ebay.com/itm/ASRock-AMD-ATX-Gaming-Motherboard-A8-5600K-CPU-8GB-G-Skill-RAM-Combo/392374025843
