Hey everyone Ive had this problem now for a while and decided to ask you guys about it. I have a Corsair strafe RGB keyboard and ive had it for 2 years, sometimes when I boot up my pc my caps light key doesnt work num lock or scroll lock too. I restart my PC, it works but sometimes it also does not. I really need your help to fix this issue I don't think It was always like this. When I upgraded from a 6700k to a 9700k and swapped my mobo, I hoped that would fix it it did not. I really need you help on this one. Thanks!
https://linustechtips.com/topic/1099197-caps-lock-light-wont-work/
Turn off the computer
.1rts: You can try  to remove the problematic keys then put some drops of isopropyl alcohol and click fast, do that 3~4 times.
Let it dry like for 30 minutes.
If the problem is not solved (It wont make it worst trust me).
:2nd you do the same think with a special spray for electronic stuff
http://www.morris-deco.com/product/2675-contact-cleaner-spray-400ml/
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
But even though the light is off for caps lock windows still recognizes it as caps lock is on so it works but the light does not indicate that it is on
Corsair have the lights inside the keys
3 hours ago, emosun said:
have you plugged a normal keyboard in yet to check if its the keyboard at fault
Ok so i plugged my sisters keyboard in and the caps lock light worked fine, then I plugged my keyboard back in and the caps lock light worked. I really don't know whats happening here
well you can either plug your keyboard into 10 different computers with the lights still not working
or i can just tell you your keyboard is broken
Try opening iCUE, going into settings, select the Strafe RGB Keyboard, then force firmware update it.  If this still doesn't resolve the issue, you can also submit a support ticket and request a hard firmware reset.  Our Technical Support team will provide you the necessary files through ticket portal.
https://support.corsair.com/
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
