Ryzen is x86 based. There are no compatibility issues.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
13 minutes ago, Melodist said:
Howdy there,
Has anyone tried Pro Tools with Ryzen? What's the compatibility? Especially Ryzen 3?
What are you worried about exactly? Ryzen is an x86-64 CPU arch. There are literally no compatibility issues across Windows and Linux
Because fuxling Avid only tests their DAW with Intel Platforms and I have not had an AMD for 10 years.
This was the main reason I've been a bit hesitant to build my first non-Intel build. The fact that the clock speeds and core assignments would change constantly was scary, but you know what, it works. The only issue I encountered so far was when I was inserting an izotope de-noiser while playback was running and PT halted the playback and gave me the "CPU speed not enough blabla"-error. But I'm pretty sure that's more because of my crappy audio interface and it's ancient drivers.
So far I have worked on only the more simple projects with this PC, so not those with dozens of VI's or hundreds of tracks.
Everything is just super fast compared to my old Xeon 1230v3. From Haswell to Zen2, around the same price category, triple the bounce speed.
3700X | NH-D15 | X470-F | 2x16GB @3200MHz | RTX 2060 Ventus OC
RM650x | Fractal Design R4 | NVMe 970 EVO Plus 512GB | SATA 850 EVO 512GB
<Build Log>
