Is my parts compatible with each other?
Go to solution Solved by Energycore,
Welcome to the forums!
Yes your computer is compatible. But it's not going to perform the way you'd expect considering the buck you're spending, unless we do some tweaks to it. Can you shop anywhere in aus?
Take a look at https://au.pcpartpicker.com/
It's a site that allows you to customize your PC builds and choose from a variety of different retailers. If I had $2800 AUS and wanted a full gaming build, I'd include a monitor to enhance my gaming experience. Here's a build:
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($517.00 @ Shopping Express)
CPU Cooler: Noctua NH-D15 SE-AM4 82.52 CFM CPU Cooler  ($123.00 @ Austin Computers)
Motherboard: Gigabyte X570 GAMING X ATX AM4 Motherboard  ($308.00 @ Shopping Express)
Memory: *Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($125.00 @ Umart)
Storage: Crucial MX500 1 TB 2.5" Solid State Drive  ($169.00 @ Amazon Australia)
Video Card: MSI GeForce RTX 2070 SUPER 8 GB VENTUS OC Video Card  ($857.00 @ Skycomp Technology)
Case: Phanteks Enthoo Pro Tempered Glass ATX Full Tower Case  ($169.00 @ PCCaseGear)
Power Supply: *SeaSonic FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($141.55 @ Mwave Australia)
Monitor: Samsung LC27JG50QQNZA 27.0" 2560x1440 144 Hz Monitor  ($418.00 @ Shopping Express)
Total: $2827.55
Generated by PCPartPicker 2019-08-25 14:56 AEST+1000
You can throw in the RGB fans if you like, or change the air cooler to an AIO though it will be slightly louder. You also don't need a sound card, especially not a "gaming" sound card. If you want audiophile sound, it takes committing into multiple pieces of hardware, specifically a DAC and Amp and you'd have to do some research.
Let me know what you think :)
So I am building a pc from Scoptec and I wanted to know if my parts are compatible I have AUS $2800 to spend and I want to get the best for my buck thanks for the help.
Specs
Core: Intel I7 8700 (4.6GHz)
Ram: G.Skill Ripjaws V 32GB (2x16GB) PC4-25600 (3200MHz) DDR4, 16-18-18-38-2N, 1.35V, Dual Channel Kit
CPU Cooling: NZXT Kraken X72 Liquid CPU Cooler, 360mm Radiator, Aer-P Radiator-Optimised 120mm Fan x3, Reinforced Extended Tubing, NZXT CAM Powered with Advanced Lighting Modes, Compatible with AMD Threadripper CPU up to 250W
GPU: Gigabyte GeForce GTX 1650 Windforce OC (Boost: 1785MHz), 4GB GDDR5 (8002MHz), PCI-E 3.0, DisplayPort, 3x HDMI 2.0b
Motherboard:ASUS ROG STRIX B365-G Gaming MB, B365, 4x DDR4, 2x PCIE3.0 x16, 2x M.2, 6x SATA3, 8x USB3.1, DVI-D, HDMI, Micro ATX, Aura RGB
SSD: Kingston 480GB SSD, SSDNow UV500 3D NAND, 2.5" SATAIII, Read up to 520MB/s, Write up to 500MB/s
HDD: Seagate 3TB BarraCuda 3.5" Hard Drive, SATA III, 256MB Cache, 185Mb/s Max
Power Supply: Corsair 850W CX850M Bronze Power Supply, 80 PLUS Bronze, 120mm Fan, 1x ATX, 1x EPS, 4x PCI-E, 8x SATA, 6x Molex, 2x Floppy, Modular Cabling
Sound Card: Corsair ML140 140mm Premium Magnetic Levitation Fan Twin Pack, Magnetic Bearing, Custom Rotor Design, Extensive Control Range, 140mmx25mm, 400-2000RPM
External Fans: ASUS Strix Soar 7.1 Channel PCIe Sound Card, Sabre 116dB DNR 24-bit DAC, 600ohm Headphone Amplifier, Sonic Studio Ultility, Sonic Radar Pro
Case: Corsair iCUE 220T RGB Airflow Black ATX Case, Tempered Glass Side Window, No PSU, 2x USB 3.0, HD Audio, 3x 120mm SP120 RGB Pro Fan pre-installed, Steel
https://linustechtips.com/topic/1097696-is-my-parts-compatible-with-each-other/
that rig looks like a train wreck. do you need everything to be scorptec only or are other sites fine?
PCPartPicker Part List: https://au.pcpartpicker.com/list/XvKX9J
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard  ($289.00 @ Shopping Express)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3600 Memory  ($158.00 @ Amazon Australia)
Storage: Kingston UV500 480 GB M.2-2280 Solid State Drive  ($122.00 @ I-Tech)
Storage: Western Digital Blue 3 TB 3.5" 5400RPM Internal Hard Drive  ($115.00 @ Umart)
Video Card: Gigabyte GeForce RTX 2080 8 GB WINDFORCE Video Card  ($1089.00 @ BudgetPC)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($149.00 @ PCCaseGear)
Power Supply: SeaSonic PRIME Ultra Gold 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($283.00 @ Skycomp Technology)
Total: $2845.00
Generated by PCPartPicker 2019-08-25 14:47 AEST+1000
Every component in the build i am suggesting is much better.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
Total: $2827.55
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Motherboard: ASRock X570 Steel Legend ATX AM4 Motherboard  ($319.00 @ Mwave Australia)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($125.00 @ Umart)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive  ($89.00 @ Umart)
Storage: Toshiba P300 3 TB 3.5" 7200RPM Internal Hard Drive  ($119.00 @ Scorptec)
Video Card: Gigabyte GeForce RTX 2080 8 GB GAMING OC Video Card  ($1055.00 @ Mighty Ape)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  ($108.00 @ Shopping Express)
Power Supply: Cooler Master MWE Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($110.00 @ Shopping Express)
Total: $2442.00
Generated by PCPartPicker 2019-08-25 15:13 AEST+1000
I have a budget of AUS$2800 I would like an Intel core, 32gb of ram and liquid cooling if possible I already have a keyboard, mouse and an MSI 27inch FHD Curved 144Hz FreeSync Gaming Monitor, 1920x1080, 1ms. thanks for the help.
Well...it does depend on what you are doing...If just gaming...and you don't WANT to spend your entire budget...
For strict Price/Perf...
For audio...decent AMP/DAC combos for a decent price(prices are in US so take as an example.)
Syba Sonic $42
Sabaj D3 $110
Topping NX 4 $160
Topping DX PRo $220
https://www.reddit.com/r/Zeos/comments/97mi5s/zguides_headphones/
He is sound expert.
here is another
audiosciencereview.com/forum/index.php
and here are cpu heatsinks...though unless you OC you probably are not gonna see any price/performance from this...
http://www.frostytech.com/top5_liquid_heatsinks.cfm They have air coolers as well.
what are you doing that needs 32gb of ram? why only intel?
Oh in that case we can drop the monitor from my build and upgrade the GPU.
Case Fan: Corsair SP120 RGB 3-Pack w/Controller 52 CFM 120 mm Fans  ($67.00 @ Shopping Express)
Total: $2758.00
Generated by PCPartPicker 2019-08-25 16:09 AEST+1000
Computer Specs:
My recommendation...
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($119.00 @ PCCaseGear)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  ($155.00 @ Austin Computers)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory  ($129.00 @ Shopping Express)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($166.00 @ Skycomp Technology)
Video Card: MSI Radeon RX 5700 XT 8 GB EVOKE OC Video Card  ($729.00 @ Austin Computers)
Power Supply: be quiet! Pure Power 11 600 W 80+ Gold Certified ATX Power Supply  ($119.00 @ PCCaseGear)
Total: $2083.00
Generated by PCPartPicker 2019-08-25 16:10 AEST+1000
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
1 minute ago, Schnitz said:
I like intel because I tried AMD and it was kind of shit and I have 8gb right now and it gets eaten up by chrome and discord
Have you specifically tried RYZEN ???
SSD TIER LIST
CPU - Ryzen 7 3700X
unless you have 10000 chrome tabs, 16gb is gonna be more than enough. AMD has stepped up quite a lot since bulldozer, the 3700x now isn't much worse than the 9700k and 8700k in games.
....okay....when did you try them?
times change...the $200 r5 3600 plays games with the best of them...though the 9900k OC slightly beats it out.... for a MASSIVE premium.
again...if you care for price/perf For GAMING...you will not spend your entire budget..if you prioritize differently(Streaming/Graphics editing/VMs)..then obviously you can upgrade the Cpu to a 3700x and for a Premium...can go to 2080$uper or Ti
In your market...once you pass about 2k$ you have exponential Diminishing Returns.
8 hours ago, LukeSavenije said:
 come on dude, i expected better from you
Yo when I was around the refresh of the focus that caused all that ripple didn't exist, give some time to catch up man :(
Computer Specs:
i mean... i have written about it
and I'll teach you everything when you need it
